Door Ajar Malfunction - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-10-2013, 08:08 AM Thread Starter
Hey Everyone,
I have a 2003 6.0L powerstroke and I know that the door ajar sensors are a common issue on these vehicles. It seems like its common for people spray a lot of cleaner/lube into the door latch components and say that it goes away. I have had a bit of a different response when I did this. I know that the passenger front door is responsible, I sprayed some brake clean in the latch (to clean out the dust) and than sprayed some white lithium grease in there to lube it up. Now when I open the door, the light turns off, and when I close the door the light turns on, its like the switch is working backwards. I was wondering if anyone else had this problem before, does it sound like something that requires the replacement of the latch, or just more cleaning? Any help would be appreciated. Thanks!
and.decarlo is offline
post #2 of 6 Old 09-10-2013, 09:13 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Hahah, now that's funny. I hate when stuff works asbackwards! I'd say replace it.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 6 Old 10-22-2013, 06:12 AM
ATV PRO 11's Avatar
I've had the problem on my windstar and repetitivaly on the eX.
BRAKE CLEANER ONLY and I haven't had the problem since. Key, IMO, is to get the lube out of there that collects the dust ect.
ATV RACING.......cause football, soccer, baseball, tennis and GOLF only require ONE BALL
Curtis
04 Excursion Ltd
6.0 Studded
EGR Delete
PHP Gryphon9
Swamps 58V FICM
AFE Stage 2 intake
4" Turbo back w/5" tip
Deaver springs front, Icon Dynamics rear 6" lift
Dual Fox w/resi's front, Fox w/resi's rear
Custom fit Bushwacker Flare's
4:88 gear, Detroit Rear
Front/Rear DVD w back up camera
1500W of Kicker power
42" Goodyear MTR winter
37" Yokohama Geolander summer
ATV PRO 11 is offline
post #4 of 6 Old 10-22-2013, 07:45 AM
Quoted: 8 Post(s)
Since you get rid of all the lube, does that mean you like it dry?
I disagree and think it is the lubrication that helps these door sensors.
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #5 of 6 Old 10-24-2013, 08:07 PM
ATV PRO 11's Avatar
I sprayed brake cleaner in there last spring and it's hasn't acted up on my nor caused any other door malfunctions for me. With my old windstar i'd lube it, it would go away for a couple 3 weeks and happen again. Same with my eX when I got it. lube it (graphite, all purpose, WD ect ect) and it would always come on within a couple weeks. I was desperate with the eX. With the amount of lights that stay on when I lock er up for the night and the length of time they stayed on for she was close to not starting up the following day a few times.
Curtis
04 Excursion Ltd
6.0 Studded
EGR Delete
PHP Gryphon9
Swamps 58V FICM
AFE Stage 2 intake
post #6 of 6 Old 09-11-2014, 05:02 AM
well i figured it out, the 05 switchs seem to work in the opposite then the 03 switches, installed an 05 switch in drivers door and presto it worked! so check your part numbers!
thanks for all the replys
JonnyArch is offline
Tags
door ajar
