2005 F350 charging issue - Ford Powerstroke Diesel Forum
post #1 of 11 Old 09-09-2013, 06:56 AM Thread Starter
I have had a very weird charging problem I cannot figure out.
Every once in awhile my truck would hard start or no start. Dead batteries. Jump start and truck would be fine for days, even weeks.
Then same thing again.
Never saw the charging light on the dash at all.
Jump started it once and threw a meter on it. 13.6+/- volts. I figured, alternator is ok.
Happened several more times. I changed alternator. Truck was fine for a few weeks.
NOW, I am beginning to see charging light on dash every once in awhile. Stays on for a few seconds at a time. Weird.
Load tested both batteries(Optima red tops bought new in 2009) Load test fine. Hmmmm. Ran temporary wire from alternator to battery to see if I had bad charging wire.
This morning, got in truck to move a trailer around. Charging light was on the whole time(10-15 minutes or so).
Shut truck off. No start. Batteries dead.
Jump started. Light still on. System not charging and no battery power at all and truck actually died from no power.
Jump started. Charging fine, no light!!!!!!!!! Truck never gave me another problem all day.
WTF is going on???? Anybody got any ideas?
I have heard that something in the computer actually tells the alternator to charge or not charge? Any truth to that?
I am stumped
Tim98TA is offline
post #2 of 11 Old 09-09-2013, 07:42 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
I'd double check all cable ends and grounds... Battery to block, block to cab, and cab to frame. never hurts to beef up the ground straps either! Better yet triple check those connections. Grounding issues can cause all sorts of weird issues.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 11 Old 09-09-2013, 07:43 AM
Quoted: 8 Post(s)
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #4 of 11 Old 09-11-2013, 03:27 AM Thread Starter
Ever since Sunday morning, I haven't had a problem at all.
Haven't seen the charging light on the dash at all.
Got in it this morning and it barely started.
Tim98TA is offline
post #5 of 11 Old 09-14-2013, 12:29 AM
Quoted: 8 Post(s)
Might be the voltage regulator inside the alternator. It's not impossible to have a remanufactured alternator w/built in voltage regulators be problematic right off the shelf. Have the alternator/voltage regulator tested.
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #6 of 11 Old 09-17-2013, 03:41 AM Thread Starter
Ok, I am still having the issue. Here are the things I have done:
- Run temp wire from alternator to battery
- Run temp wire from battery to fender ground
- Cleaned up grounding location on engine block
- Cleaned all battery posts.
- Checked plug in connection on alternator
- Checked plug on fenderwell where looped wire is
I have found that sometimes the dash light will be on solid and won't go off. Sometimes I can cut truck off, let it sit for about 30 seconds, start it back up, NO LIGHT.
Sometimes driving down the road, light will flicker on for maybe 1-2 seconds. It may do this every 15-20 miles if driving down highway.
I have heard that the pcm actually tells the alternator when to charge or not charge. Any truth to that?
I am going to change the alternator one more time this weekend.
Tim98TA is offline
post #7 of 11 Old 09-17-2013, 12:02 PM
F350R's Avatar
Quoted: 10 Post(s)
You have a bad alternator. Mine when doing the same would even pass a bench test I took it apart and performed the internal tests for the slip rings and it failed. Two NAPA alternators later that only past about 8 months I gave up. DC Power is your best bet and never have to replace it again.
2004 F-350 CC LB Lariat FX4, SCT Erics Street tune, BPD EGR Cooler, BPD oil cooler, Empty CAT, Snows Water / Meth, Coolant & Oil bypass filters, 265x70x19.5 on American Force wheels, On board air system, Firestone air bags in cab regulator, dual air horns
F350R is offline
post #8 of 11 Old 09-17-2013, 01:09 PM Thread Starter
Yeah, I'm gonna change alternator this weekend.
Tim98TA is offline
post #9 of 11 Old 09-17-2013, 01:17 PM
mrenn's Avatar
Quoted: 3 Post(s)
Had the same issue few years back. Check your FICM Voltage too.Mine was bad,caused it to barely crank over.
ARP,EGR Delete,SCT,4.56 gears,powermax,Banks Techni-cooler,Adrenalin HPOP,Donohoe springs,fox shocks,airbags,blue spring,38x15.5 M. Thompson's,4 10's,2 tv's,playstation,amp-steps,2013 tailgate,edge cts
2016 Lariat 6.7.
mrenn is offline
post #10 of 11 Old 09-17-2013, 01:32 PM Thread Starter
Well if batteries are charged, turns over just fine.
Tim98TA is offline
