Edge insight CTS? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 09-06-2013, 11:55 AM Thread Starter
Edge insight CTS?
I just received this in the mail and had a question on the PID that are available. I have already sent an email and left a message with Edge and haven't gotten a call back yet, so I thought I would ask everyone here.
I hooked up the device to my computer to make sure it was updated before I pick up my truck tomorrow. In the list of PIDs it doesn't show EOTas an option. Does the device have to be connected to the vehicle in order for this to show up as option or am I missing something else?
JJensen79 is offline
post #2 of 7 Old 09-06-2013, 01:29 PM
Yes. Once you hook it it up it will ask you the make of your vehicle. When you select ford it will automatically enable the pids that apply to your vehicle. Then they will show up in your list of available pids.
mfdengineer is offline
post #3 of 7 Old 09-06-2013, 01:42 PM
Boog's Avatar
Garage
Im still looking for Engine Oil Pressure PID......anyone know if its on the CTS?
2006 F-250 Lariat CC 4X4
S&B CAI
SINISTER COOLANT FILTER
EDGE CTS MONITOR
PHP 40 ATLAS
LEVELED W/ BILSTEINS
Boog is offline
post #4 of 7 Old 09-06-2013, 03:38 PM
I don't believe ford supports engine oil pressure. You would have to add that on yourself.
post #5 of 7 Old 09-06-2013, 03:45 PM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
no did doesn't support the engine oil pressure. But I wouldn't be too worried about that. Our trucks won't run if the oil pressure gets low. Like an engine saver if you will. You can do a separate gauge, but I dont know wether the tap fir it is the same place as it is on the 7.3. Mine is a square 1/4 npt plug, that's on the drivers side of the engine, on the last rib of the block half way up. Its next to my oil filter, but since your oil filter isn't there, I can't reference it much better than that
Sent from AutoGuide.com App
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #6 of 7 Old 09-06-2013, 05:43 PM
I did forget to mention that it does monitor the injector pressure which is from the high pressure oil pump if you're interested in that
post #7 of 7 Old 09-06-2013, 06:03 PM
Boog's Avatar
Garage
Excellent.....thanks for the info.
S&B CAI
EDGE CTS MONITOR
PHP 40 ATLAS
Boog is offline
