Tail lights - Ford Powerstroke Diesel Forum
post #1 of 1 Old 09-03-2013, 07:46 AM Thread Starter
Right Tail light - UPDATE!!
06' F350 - right rear tail light and brake light not working. Flasher is blinking fast as if bulb was burned out but the bulb is new and good.
Wiring issue ???. multi function switch issue???
Forgot to mention, the right front signal light does work but blinks fast.
Running lights work all around.
I tried a new multifunction switch - no change
So I tested wires back from light all the way to the front.
Found the plug up by the relay box had come out part way, pushed it in all the way and right side works again.
Ironman44 is offline
