seal beam to composite conversion - Ford Powerstroke Diesel Forum
post #1 of 2 Old 09-02-2013, 11:15 PM Thread Starter
cmagee's Avatar
just wondering what all is required. according to silvania, my bulbs are different to those found in the composite style headlights so i'm wondering if anyone makes a kit or if a junk yard will be my best bet for this. any help is appreciated
EDIT: been doing some more research, it looks like the conversion isn't too difficult on xlt model trucks to convert to aftermarket headlights. i'm just looking now to see if there is anything else i need since i have the "work truck" headlights
Colten
03 RCLB 4x4 6spd 6.0, GT3788VA, AFE stg 2, deletes, oil cooler, p/p heads/valve guides, ported intake manifold, updated springs, oil o rings and fittings, 58v FICM with mild flash, blue spring upgrade, 6.4 banjo bolts, 155/75 injectors, FASS lp, 3"dp to 5" exhaust, studs, autometer boost, pyro, fuel, 550hp clutch, 8" lift, 37x15 toyo mt's, 485hp/912tq on stock tuning
cmagee is offline
post #2 of 2 Old 10-03-2013, 12:45 PM
Always Faithfully Broken
6pointbroken's Avatar
According to this forum it should be straight forward.
Headlight conversion on an XL - Ford Truck Enthusiasts Forums
2004 F350 SRW 6.0 ZF6 CCLB---SOLD
1997 F250 SRW 7.3 Auto ECLB
Rebuild in progress due to neglected Rust
2006 F350 SRW 6.0 Auto CCSB
Blue Spring, MBRP 4.0 straight pipe, Edge Evolution CTS 2, Dieselsite coolant filter, Dieselsite fuel/water separator, Bulletproof harness saver, Bulletproof HCFM drain plug.
2014 Focus ST
6pointbroken is offline
