factory door keypad code - Ford Powerstroke Diesel Forum
post #1 of 11 Old 08-17-2013, 10:50 AM Thread Starter
mrc228's Avatar
Where can I find the factory door code (without going to a dealer and having them plug into the obdII). I've tried looking up the info and get lots of conflicting areas under the dash to look. This is for my 2006 F250..
Any help would be greatly appreciated
'06 F250 CC FX4 - 127k miles
Under the hood
EGR Delete, Upgraded oil cooler, upgraded stc fiting /w new HPOP, Blue Spring, 4" Turbo Back, SCT tuner /w Wildman Extreme & Street tune, Sinister Diesel Coolant Filter
studs to come
In the cab
Pillar Glowshift gauge package (EoP/Fuel press/EGT), Dashboss
Alpine touchscreen nav head unit, bluetooth, Phoenix Gold 4-channel amp, JL Audio's 6.5 components up front, 5x7's in rear doors, 10" sub behind seats.
mrc228 is offline
post #2 of 11 Old 08-17-2013, 05:37 PM
ynpmoose's Avatar
Quoted: 7 Post(s)
ynpmoose is offline
post #3 of 11 Old 08-17-2013, 06:39 PM
RetiredFD's Avatar
First off, is is a OEM keypad from the factory, or an aftermarket keypad from Ford.
OEM keypad has a card with the manual, or a white label under the dash with the 5 digit number in black printing.
If its an aftermarket, you are SOL.
- Chris
2006 F250 CCSB Lariat
RetiredFD is offline
post #4 of 11 Old 08-18-2013, 09:55 AM
i used to install the aftermarket type keypads and some of them had a default code like 12345 or all 0 or 9.
2006 F250 PSD-Fabtech lift,King Coil overs,AMP steps,37's,some other bolt ons.
1965 Mustang Fastback-
Sound Decision Car Audio-MECP Certified
Ford Master Tech
iskwezm is offline
post #5 of 11 Old 08-19-2013, 04:19 AM Thread Starter
mrc228's Avatar
As far as I know it's factory. I've never had the manual. I've looked on a few places under the dash behind the radio etc. but I've never been able to find the location for the module on an 06. From what I can gather different year have it in different locations and excursions also differ in location.
Sent from AutoGuide.com App
Under the hood
studs to come
In the cab
mrc228 is offline
post #6 of 11 Old 08-19-2013, 12:23 PM
USAFBowman's Avatar
So I have a stick on Ford one, and I have the door pad code on the card.
I have replaced the battery to the key pad. Is there a way to reprogram the keypad to the truck?
USAFBowman is offline
post #7 of 11 Old 08-19-2013, 04:22 PM
I had to pull the fuse panel trim. Kind of foggy memory now. Had a few since then. Look back toward radio behind white padding with a mirror. Stole wifes and taped it to a tongue depressor. Not sure why I had that. Worked though. 5 digit code as previously mentioned. I'll pull mine back and take a picture if you still need to see it.
2005 Excursion-6.0 Powerstroke-Arp Headstuds-EGR Delete-Powermax Turbo-SCT Livewire TS-More to come
CRichardson is offline
post #8 of 11 Old 08-19-2013, 06:49 PM Thread Starter
mrc228's Avatar
Yes please. I've looked behind the radio a little when I had it out a while back but may not have looked deep enough.
Under the hood
studs to come
In the cab
mrc228 is offline
post #9 of 11 Old 08-22-2013, 01:48 PM
Evilmonkey's Avatar
Here's a good writeup for the code location.
2005-2007 Key less Code Retrieval
Evilmonkey is offline
post #10 of 11 Old 08-23-2013, 04:13 AM Thread Starter
mrc228's Avatar
Bingo!! Thanks
Under the hood
studs to come
In the cab
mrc228 is offline
