Batteries or Alternator? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-15-2013, 06:27 AM Thread Starter
Hi All!
I have a 2005 6.0PS. I noticed last weekend the truck would not start up as quick as usual. And the other morning, I went to head out to work and it was dead. Checked the voltage, 10+ volts. I put the charger on if for a while and got it running. I put the computer on it and found the car was putting out in the 11's at idle and would run up into the low 13's at higher RPMs. If I add lights and radios the voltage goes down. But it stays around 13.
Its been raining so basically I have just been leaving it on the charger over night and taking it to work and its been fine. Last night it was pouring, so I didnt put it on the charger and it was dead again this morning. I put a quick charge on it and got it started with a boost. Today I was looking at 9v and was lucky to get high 11s. If I turned off all lights, radios, A/C, etc I could get 12s.
I am leaning towards batteries, but would welcome your thoughts.
I am using AutoEnginuty to keep an eye on things, and yes I was watch the FICM as well and never dropped below 48 (phew!)
Thanks!
John
jmcboots is offline
post #2 of 3 Old 08-15-2013, 07:09 AM
DBM
sounds like the alternator to me, your idle voltages are too low
"have not shot the gun yet but will next week when we see the mother in law." Quoted from a gun forum!
2004 CC 6.0 4x4 lariat
MODS: BPD Remote Oil Cooler, MTW Stage 1, GoGo Diesel Direct Drive Soleniod, Swamps 58v FICM, ARP's, Sinister EGR Delete, SCT XCAL3 w/DJ's Looney, Dfuser coolant filter, 4" straight pipe, Ranch Hand, Tuff-Country Level Kit, Isspro Boost/Trans Temp/Fuel Pressure/Pyro gauges, Edge Insight CTS...
DBM is offline
post #3 of 3 Old 08-15-2013, 07:34 AM Thread Starter
Thanks DBM!
jmcboots is offline
Tags
alternator , battery
