Alternator Change Out Before FICM? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 08-12-2013, 02:39 PM Thread Starter
Guy_K's Avatar
Hey Fellas,
My FICM finally cr@pped out. I ordered a new one from FICMrepair along with a new 185 amp DC Power alternator. Ed told me to change out the alternator first before I change out the FICM or it will fry the FICM. I don't understand how if I leave the batteries disconnected until the end of both jobs. Any ideas?
I received the FICM today and would like to get that replaced before the alternator shows up tomorrow. My alternator appears to be putting out low voltage but still in the 12.5v-12.9v range after Glow Plugs kick off.
Does he mean don't do the complete alternator install (hook up the batteries) while the FICM is disconnected? I could see how that may be a problem because someone could hook the batteries back up by accident, then plug in the FICM.
Thanks in advance!
2005 F250 XLT 4x4 6.0L
4" Lift, 315 Tires, Edge Insight CS w/ fuel pressure and EGT, Gearhead SRL+, Blue Spring, Sinister Coolant Filter, door seal mod, Hybrid Audio Imagines, JL 13TW5, JL 900/5, Dynamat, ect...ect..
Sinister (bulletproof style) EGR Cooler, Updated Ford Oil Cooler, ARP Studs, Updated EGR Valve, HPOP, and IPR by Underground Diesel Performance
Guy_K is offline
post #2 of 15 Old 08-12-2013, 02:56 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Is the existing alternator charging correctly?
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #3 of 15 Old 08-12-2013, 02:58 PM
ZMANN's Avatar
Quoted: 1469 Post(s)
if your current charging system is fine this includes batteries and cables ETC then it would be ok to swap FICM's
but ED has a required minimum voltage at start up IIRC and it almost exceeds
a new charging systems capabilities from what I recall
We Miss you Ronnie
ZMANN is offline
post #4 of 15 Old 08-12-2013, 02:58 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
I think (and I may be wrong) is that he does not want you to run the new FICM on a weak alternator at all. Wait to fire it up when you have the new healthy alternator in.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 15 Old 08-12-2013, 03:00 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
And something I do just for chyt's and giggle is when ever Im working on the truck I throw the batt charger on there just to top off the system. Anything I can do to help the FICM out.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #6 of 15 Old 08-12-2013, 03:00 PM
ZMANN's Avatar
ps just wait until tomorrow and do the alt and see if it's up to par then the FICM
this is just the safest way
We Miss you Ronnie
ZMANN is offline
post #7 of 15 Old 08-12-2013, 03:13 PM Thread Starter
Guy_K's Avatar
Thanks for the replies! I topped off the batteries last night and they are good to go.
I guess its the "Whatever you do.... don't push the red button..." in me.
I'll wait till tomorrow and let you guys know how it goes.
Thanks for the help! This site rocks!
Guy_K is offline
post #8 of 15 Old 08-12-2013, 04:44 PM
Quoted: 57 Post(s)
I think this is exactly right!
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDCV Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Radius Arms
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #9 of 15 Old 08-12-2013, 04:46 PM
Quoted: 57 Post(s)
And you will love the DC Power alt. I could swear my truck started running better as soon as I installed mine!
Carli Radius Arms
Carli Track Bar
Previous:
All the BPD goodies
skanj0 is offline
post #10 of 15 Old 08-12-2013, 05:11 PM
Don't forget about steps #13 and #17! FICM Repair.com - Your Source for FICM Repair
'06 F-350 SRW 6.0 PSD
Albin is offline
