2nd Alternator for AC power - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-12-2013, 12:21 PM Thread Starter
06_Whitebull's Avatar
Here's a question for the DC electrical guys.....
Info: 2006 F350 Lariat FX4, single alt (DC Power XP 250 amp)
Plan: I am exploring installing a dual alt. system, using the second alt. to charge a battery bank mounted to either the frame or in the bed and using that bank to power an inverter in the cab.
Question: Can I run the second alt. without plugging it into the PCM? I know in the dual alt. trucks the PCM controls both, but my battery charger will be controlling the charging.
06_Whitebull is offline
post #2 of 4 Old 08-12-2013, 05:00 PM
Quoted: 58 Post(s)
Sure, as long as you get one of the older style "1 wire" alternators. Then, as long as the motor is running it will charge. Just dont connect this alt to your truck batteries or you will cook your glow plugs when they cycle on.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDCV Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Radius Arms
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #3 of 4 Old 08-12-2013, 05:04 PM
Smoke Eater
Feedback Score: 5 reviews
Send a message via Yahoo to fdchief
Correct if you run the second alternator make sure you have it hooked up as a true "stand alone" ie hooked to nothing but your inverter for your ac needs.
2007 F-250 Lariat Crew Cab
SPL LED Lightbar
20" Fuel Rims
35" Nitto MT's
SCT Livewire w/ Tony Wildman Tunes
PMM Full EGR Delete/ Coolant Kit
Hornblasters 540 Kit
LED Lightiing All Around
All kinds of other Goodies!
2005 Lariat Crew- GONE!
2011 Lariat Ultimate Crew- GONE!!!
Back in a 6.0hhhhh and lovin it!
fdchief is offline
post #4 of 4 Old 10-04-2013, 05:32 PM
mtpolarbear's Avatar
If you have the right size main alt. then you don't need to waste the money on a dual setup with extra batteries. I have a 2000 watt inverter with a single 250 amp alt. and zero problems. My $.02 worth
POLARBEAR - 2003 F-250 SD CC SB FX4, 6.0, 3:73 gears, EGR & Cooler Delete, Bulletproof Oil Cooler, ARP Studs, A.R.E. Topper, Bedrug, Zoodad, 5" Magnaflow turbo back, K & N cold air intake, coolant filter, EDGE INSIGHT CTS, SCT X3 Tuned by Vivian, Energy Suspension Master Bushing kit, RiffRaff Boots, Blue Spring, 6.4 Banjo's, Fumoto Oil Valve, Fumoto water drain plug, Whistler 2000 Watt Inverter, DC Power 200amp Alt. Rebuilt FICM w/Atlas 40, Riff Raff Boots and counting.
mtpolarbear is offline
