Trailer lights! 911!!! - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-06-2013, 06:55 PM Thread Starter
mrc228's Avatar
Nothing like waiting until the last minute right? Leaving for vacation tomorrow and have a little issue in my lights coming from the truck side.
Hooking up the boat to the factory 4 pin plug and all I have are brake lights and I only have those when I turn the truck lights on. I thought it might be the boat wiring but I'm using a meter AT. The truck plug and I have the same thing. As far as I know it's all factory wiring. Is there a fuse I need to look for or should I just get the adapter to take me from the 7 pin down to a 4 pin?
Sent from AutoGuide.com App
'06 F250 CC FX4 - 127k miles
Under the hood
EGR Delete, Upgraded oil cooler, upgraded stc fiting /w new HPOP, Blue Spring, 4" Turbo Back, SCT tuner /w Wildman Extreme & Street tune, Sinister Diesel Coolant Filter
studs to come
In the cab
Pillar Glowshift gauge package (EoP/Fuel press/EGT), Dashboss
Alpine touchscreen nav head unit, bluetooth, Phoenix Gold 4-channel amp, JL Audio's 6.5 components up front, 5x7's in rear doors, 10" sub behind seats.
mrc228 is offline
post #2 of 3 Old 08-06-2013, 07:18 PM
jesilvas's Avatar
Quoted: 2 Post(s)
If it's not working on 4way, 7way factory just uses the 4way wiring too. You can try that though.
There are fuses that it can be. But you may have just a dirty connection behind the bumper.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 3 Old 08-06-2013, 08:31 PM Thread Starter
mrc228's Avatar
Found it. Blown fuse under the hood.
Under the hood
studs to come
In the cab
mrc228 is offline
