Uplifter switches - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-04-2013, 11:50 AM Thread Starter
Uplifter switches
My truck is an 06 250 lariat it came equipped with the brake controller with the cubby next to it. I would like to put the uplifter switch block in its place. Is my truck already wired for this? I would like to run LED light bar and Off road lights in my bumper with that block it just looks cleaner. Thanks in advance.
wingsandwalleyes is offline
post #2 of 4 Old 08-04-2013, 12:19 PM
Order the switch and wiring harness and you'll be good to go. The wiring harness will come with the relay box that mounts above the glove box on the passenger side. You'll have to fish the other end through the dash to the fuse box on the drivers side. I added the switches to mine and it wasn't difficult at all. Just takes some time.
I don't have the part numbers handy but there is a write up here somewhere that has alot of good info. Thats what I used to do mine.
mfdengineer is offline
post #3 of 4 Old 08-04-2013, 12:56 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Got my switch's from Dylan at AUTOFAIR. Best price by far that I could find.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #4 of 4 Old 08-04-2013, 03:30 PM
305f250's Avatar
tasca parts $100
305f250 is offline
