Glowshift wiring - Ford Powerstroke Diesel Forum
post #1 of 53 Old 08-03-2013, 05:38 AM Thread Starter
paintballbryce's Avatar
Glowshift wiring
Hi guys,
Got my glowshift 3 in 1 gauge in last night, and was wondering what you found was the easiest way to run the wires that power the gauge. Im running the positive and negative right to the battrery, but wanted some ideas on where to run the others that are close and easy to access!
Thanks!
2006 F250 Bulletproofed - SOLD
2008 F350 King Ranch
Stock for now
paintballbryce is offline
post #2 of 53 Old 08-03-2013, 06:29 AM
mikegoslin09's Avatar
I made a couple of cuts from in the wiring harness they sent me. Made a common positive, ground, and dimming wire coming off the back of the gauges so I only had to worry about running and snaking 3 wires, a boost line and my egt wires instead of the mess they sent you. I just ran mine through the hole from the factory oh s**t handle and down behind the dash next to the door jamb. From there they pip out right under the dash for splicing in to the headlights. I used a bolt under the dash for a ground and an add a circuit for my power. Pretty easy. I can send pics if you need.
2004 F350 6.0L Powerstroke FX4
72,000 miles and climbing
4" MBRP turbo back to 6" stack
SCT SC3, tunes from Eric @ Innovative Diesel
Edge Insight CS
GlowShift Boost, Fuel Psi, 2400* EGT gauges
Blue Spring Mod
Zoodad Mod
Venom Wheel 2" spacers
Still running Ford Gold with great deltas, good coolant pressure. Healthy truck.
mikegoslin09 is offline
post #3 of 53 Old 08-03-2013, 07:45 AM Thread Starter
Please do! Im a newbie to this kind of wiring,
Thank you very much!
Stock for now
post #4 of 53 Old 08-03-2013, 07:56 AM
I will post them as soon as I pick up my truck. Shop just called me and my exhaust manifold job is done. Just have to get a ride to get her
Edge Insight CS
Blue Spring Mod
Zoodad Mod
post #5 of 53 Old 08-03-2013, 08:15 AM Thread Starter
Awesome! Im going to start taking my engine apart to get at the fuel bowl for my sensor, and then try and figure out how to do my boost and probe!
Thanks
Stock for now
post #6 of 53 Old 08-03-2013, 08:19 AM
You don't have to take too much apart to put that sensor in. Just get that radiator hose out of the way. Boost line won't be an issue either. I will post them when I get back.
Edge Insight CS
Blue Spring Mod
Zoodad Mod
post #7 of 53 Old 08-03-2013, 08:38 AM Thread Starter
The white and the orange are my main concern on doing, positive and negative are going right to battery. Not sure on the boost and egt, but ill try and figure it out. Have you painted your pillar yet? I ordered tan, when my interior is grey! So I either need to paint it, or plastidip it.
Stock for now
post #8 of 53 Old 08-03-2013, 12:26 PM Thread Starter
Should I be turning the screw away from the fuel bowl or towards it to get it out?! Seems likes its tight in there!
Thanks!
Stock for now
post #9 of 53 Old 08-03-2013, 02:13 PM
http://http://www.google.com/search?...DwJBYQnCk4M%3A
Edge Insight CS
Blue Spring Mod
Zoodad Mod
post #10 of 53 Old 08-03-2013, 02:14 PM
That's where your sending unit will screw into. Still can't get pics cause of a thunder storm. Don't force it. If you snap them, you have to buy a whole new filter housing. $300 to find that out
Edge Insight CS
Blue Spring Mod
Zoodad Mod
