Dome,cargo,step rail lights don't work - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-02-2013, 06:20 PM Thread Starter
2006 ford f350 put LEDs in dome light putting it back it started sparking. When I finally got it on dome didn't work then noticed cargo and step rail lights lights didn't come on either checked all fuses they are all good called dealer and he said that the interior light relay is integrated with the damn cluster so he said you have to buy a new cluster $400 - $500 I don't want to spend that much just for interior lights. Got on Internet and read that people well get the black/lt blue wire which as no power cut it and put a toggle. My question is if I so that does everything work normal like turn on lights with remote and also turn off if doors stays open? Or it will only turn on if I flip the switch?
Sent from AutoGuide.com App
Welder361 is offline
post #2 of 3 Old 08-02-2013, 07:20 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
If your apply power thru the switch to the dead wire... It will only light up when the switch is turned on.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 3 Old 08-02-2013, 07:39 PM Thread Starter
Can I splice into the battery saver wire light green/ yellow to black/lt blue wire or it won't do anything. I'm just asking cause if the lights won't come on when I open door I have no need for a toggle cause map lights still work
