hoooking up amp and sub....help - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-28-2013, 07:20 AM Thread Starter
so for all you guys and gals who have hooked up a system in your trucks where did you guys run the wires from the head unit to back of the truck? also where did you guys mount your amp because I have the metal tray under my back seat and really don't want to get rid of it. if anyone has any links to a write up or some pictures or anything please post them. I searched and searched and came up with nothing.
duracrap is offline
post #2 of 8 Old 07-28-2013, 08:44 PM Thread Starter
Anybody wanna help? Lol
duracrap is offline
post #3 of 8 Old 07-28-2013, 08:55 PM
drivininidaho's Avatar
Quoted: 81 Post(s)
where your back seat lays down. there are two open spots back there where you can mount a sub and amp.also you could run your wires in the cowels in the floor along the door. you will want to run your power cables and rcas on opposite sides if you run your power through the firewall.
Lyndel
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
'04 F25 SD CCSB
studded, and having some issues.....
drivininidaho is offline
post #4 of 8 Old 07-29-2013, 06:38 PM
jlmotox's Avatar
I run my wires down the door sills, and under the carpet where needed. Carpet comes up pretty easy, or atleast enough to get an arm in there. As far as the amps, under the seat or on the back wall of the cab. I built a "mount" for my amp with a piece of wood spaced off the cab to clear the vent, just used partical board and small 1x1" blocks on the corners of the board to space it out. Can take pics if you want...
Sent from AutoGuide.com App
2005 F250 Lariet FX4 CC SB 6.0, 6" ProComp Stage2 Lift,17x9 ProComp wheels,35" ProComp xtreme AT's,Warn 12k winch w/hidden kit,Custom light bar w/4-8" ProComp,Pioneer double din Nav XM back up cam,10" kicker sub,1000w 5channel amp,15% tint, Truxedo bed cover,Firestone Bags,Airaid intake,4" turbo back MBRP exhaust,ARP headstuds
jlmotox is offline
post #5 of 8 Old 07-29-2013, 08:50 PM Thread Starter
Could you please take some?
duracrap is offline
post #6 of 8 Old 07-30-2013, 06:40 AM
jlmotox's Avatar
Hard to get a good shot...
hoooking up amp and sub....help-imageuploadedbyautoguide1375195126.667392.jpg
hoooking up amp and sub....help-imageuploadedbyautoguide1375195155.356504.jpg
hoooking up amp and sub....help-imageuploadedbyautoguide1375195230.597900.jpg
jlmotox is offline
post #7 of 8 Old 08-01-2013, 07:36 PM
For what it is worth, here are a couple old threads on my stereo install.
06 F250 Tweeter Install w/ Pics
2006 F240 Crew Stereo Install
2006 F250 Lariat Crew 4x2
tnscoutr is offline
post #8 of 8 Old 08-03-2013, 08:01 PM
My amp is mounted on a carpeted piece of board, it stands up behind the back seat. I removed the faux carpeting and have 2 10" subs mounted in individual boxes behind the seat, barely fits but sounds awesome.
2004 F350 CCSB Lariat FX4
Powermax
Edge CTS w/ EGT, Fuel Pressure
SCT tuner with Innovative Tunes
Fleetrite ELC, Rotella T-6
MBRP 4" turbo-back straight pipe
XDP Coolant Filter
NUC Motorsports Oil Bypass
Pioneer AVH3500BHS head unit, backup cam, Sirius/XM, Kicker speakers, Kicker 500.1 Amp, 2x Kicker 10" subs
89Foxbody is offline
