A/C Diode location??? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-14-2013, 10:34 PM Thread Starter
Blknite23's Avatar
issue started with the a/c fuse blowing.. so i replaced the compressor clutch... still blew the fuse so i took it to a shop and they replaced the compressor and dryer/accumulator and still blows the fuse.. shop tells me after tracing all the wires and everything they believe the diode coming from the compressor is bad... due to having a ground signal coming towards the fuse panel. they cannot find the diode DOES anyone have a idea where its located ??? 2006 f250 6.0
2006 CrewCab F250..
*Banks Big Hoss kit, Looney Wild, Studs, 6" with 37's other odds and ends
Blknite23 is offline
post #2 of 5 Old 07-14-2013, 10:41 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Maybe you should start one more thread with the same exact post again! Lol, never heard of one but I'm someone will chime in.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 5 Old 07-14-2013, 10:57 PM Thread Starter
Blknite23's Avatar
lol i asked this question about the issue with the fuse before at one location and only got nothing lol so i figured a few more threads wouldnt hurt... im just sick of no AC in SWFL and having shops tell me they have no idea...
2006 CrewCab F250..
post #4 of 5 Old 07-15-2013, 04:34 AM
Pistolgrip426's Avatar
I would tell em to put a good compressor on it,must be under warranty if they just put it on,bench test it next time first,make sure it works,alot of labor for not.,,,,,,,,,,,,,have they tested the a/c relay ?,any issues with the blower fan stopping ? or just a/c compressor blows fuse ? this could just be a junk reman compressor out of the box,very common.
2004.5 F-550,4x4,6.0,auto,CTS monitored,
Performance Machine egr delete,caterpillar elc,blue spring, CTS Monitor,flat plate agm batteries,K8 code, super tow pkg. (4.88),twin line recovery wrecker.
Pistolgrip426 is offline
post #5 of 5 Old 07-15-2013, 12:48 PM Thread Starter
Blknite23's Avatar
everything works... just when you turn on the ac in the truck you hear the compressor click then the fuse blows did the same with the old compressor.... relay is brand new, blower works great... no other issues
2006 CrewCab F250..
