Rear Tail Light and License Plate Lights not working - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-13-2013, 07:30 PM Thread Starter
Exclamation Rear Tail Light and License Plate Lights not working
Hey everyone. I have a 2006 Ford F250 6.0 Powerstroke and currently have no tail lights or license plate lights. I have brake lights, turn signals, back up lights, and even have trailer lights. I've checked all of my fuses with a volt meter multiple times and everything is reading 12 volts on both sides of the fuses. I'm hoping someone can point me in somewhat of a right direction to see what I should check next. Are there any relays that I should check and if so which ones? Thank you in advance!!!! Any help is much appreciated.
tmanrose2007 is offline
post #2 of 6 Old 09-24-2013, 06:39 PM
capcalvin's Avatar
Ever get it fixed? Having the same issue.
'03 F350 6.0 CC dually lariat 4x4
Autometer gauges:
Pyro, boost, fuel pressure
Edge insight cts
Bulletproof EGR cooler (Blocked off)
Oil cooler rebuilt
Coolant filter
Delvac EC-1 ELC
Exhaust: MBRP 4" cat back with delete pipe
SCTx3 Tunes by Innovative and Gearhead
Swamps 58v FICM
High idle mod
SRW front wheel conversion
ARP head studs
capcalvin is offline
post #3 of 6 Old 09-25-2013, 12:55 AM Thread Starter
Yeah I did. After checking everything with a volt meter I lowered the spare tire down to look at the harness. At the harness I found a wire that wasn't completely separated but it had a nice gash in it and sure enough that was it. Everything has been fine since then.
post #4 of 6 Old 09-25-2013, 04:59 AM
capcalvin's Avatar
Thanks! I'll check it out today.
Autometer gauges:
Edge insight cts
Oil cooler rebuilt
Coolant filter
Delvac EC-1 ELC
Swamps 58v FICM
High idle mod
ARP head studs
post #5 of 6 Old 09-25-2013, 05:01 PM
capcalvin's Avatar
Fixed it! Same scenario. Wire was smashed right at the plug where it splits off of the main harness.
Autometer gauges:
Edge insight cts
Oil cooler rebuilt
Coolant filter
Delvac EC-1 ELC
Swamps 58v FICM
High idle mod
ARP head studs
post #6 of 6 Old 11-10-2013, 05:15 PM
OCVeloMan's Avatar
Quoted: 183 Post(s)
Garage
investigating the same issue, Had bumpers made for the truck and everything under the rear was messed with. My instrument cluster lights are now out too....
OCVeloMan is offline
