factory brake control not very strong - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-11-2013, 07:08 AM Thread Starter
jeeplj8's Avatar
Prior to my current 05 F250, I had an 03 Excursion. There was no factory brake control option. I used a Prodigy P@, that I was very happy with. I was expecting similar performance with the factory control, but have been pretty disappointed so far.
The first thing I noticed is that despite setting the gain to 10, the trailer brakes simply do not engage as strongly as with the P2. With the P2 you could get actual lock-up if you set the gain a little too high. While I do not need to actually lock them up, it is a good indicator of the limit of adhesion and possible braking force. No matter how the Ford controller is set, I am not getting as much braking force as I did with the P2.
The second thing is that the Ford controller does not appear to be able to compensate for hill braking. I believe they both use the same principle, ie inertial braking. I know the P2 see the forward inertia of the truck, and the braking effort and compensates to give smooth braking performance. This translates on hills to enhanced braking effort for the trailer. However the Ford unit does not. I had to use the manual plunger to stop the trailer several times where the P2 had simply compensated on the same drive.
My question is: Is there anything that can be done to improve the performance of the Ford controller?
In the alternative, is there a easy retro-fit of better controller into the existing slot in the dash?
05 F250 King Ranch crew cab - bone stock for now, new to me April 2013, 56K miles
05 Volvo S60R, 300+ hp and AWD
09 Audi A4 Qautro 2.0T, AWD and 30 mpg!
06 Malibu LSV Wakesetter, 383 stroker
13 Coachmen 320BHDS - 10K lake house on wheels
81 Jeep CJ-8 (in progress); 5.7 HEMI; LJ (extended) frame, 3.5 RE lift, flatty fenders
jeeplj8 is offline
post #2 of 7 Old 07-13-2013, 03:34 AM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 465 Post(s)
Garage
I have to agree with you my brake controller stinks. I only pull a 4 quad trailer that weighs around 4500 lbs. I put it to 10 and it won't lock the brakes or anything close.
If I manually pull it over it will, it's like the controls are not strong enough on the scale ??
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is offline
post #3 of 7 Old 07-15-2013, 07:22 AM Thread Starter
jeeplj8's Avatar
I miss the ability to adjust it on the Prodigy P2. I am wondering if there are settings in the computer that change how actively it engages.
jeeplj8 is offline
post #4 of 7 Old 07-16-2013, 09:15 PM
mhatlen's Avatar
Quoted: 465 Post(s)
Garage
Let me know if you find anything out. Maybe we are the only two guys with something wrong with our brake controllers. I have a aftermarket one in my wife's Tahoe and I can really crank on the brakes to the point where the trailer stops the Tahoe.
But not in my 8600lb truck no way I have to pretty much use the trucks brakes instead??
Maybe we do have a problem with our factory controllers....................it does not work like I think it should.
7" Icon/Carli Lift
Atlas40
mhatlen is offline
post #5 of 7 Old 07-17-2013, 12:49 PM
Chatham036's Avatar
Quoted: 136 Post(s)
If I put mine around 7.5 - 8 it will stop my truck when I am pulling a 12,000 lbs load
Yall are aware that the factory brake is progressively rated? It does not just go to full power once the brakes are touched but it scales proportionally to the brake pedal position
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Chatham036 is offline
post #6 of 7 Old 07-17-2013, 12:56 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Agreed, and my trailer brake controller works great. I was 24,600 gvwc and I could use the controller to bring the truck to a complete stop from 60 mph rather quickly. Might be because your old trailer brake controller wasn't progressive and if the gain was set at 10, it would apply full power once the brakes are applied? Even at 10 when you apply the brakes they shouldn't lock up the trailer until your on the truck brakes pretty hard! If it was setup to lock the trailer brakes than the trailer brakes is working harder than the truck brakes and will prematurely were out the trailer brakes. Gotta find that happy medium...
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #7 of 7 Old 07-23-2013, 07:36 PM
STROKEDIS's Avatar
not to thread jack but you guys are kinda on a subject i need to know more about. changed out my factory brake controller and the brake pressure sensor ,but still no signal sent to trailer .hooked up to buddies truck trailer brakes work fine !!! had a tbc code on dash for awhile then changed out controller but no luck!!! any help much appreciated !STROKEDIS
05 sd ,banks six gun tuner ,arp head studs ,bullet proof diesel egr cooler,upgraded fuel pump,upgraded fuel regulator banks air filter , turbo back 4 inch exhaust, 8 " lift 37's with 4.56 gears
STROKEDIS is offline
