Door Ajar Problem - WD40 was no help - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-03-2013, 04:06 PM Thread Starter
Hey guys, I'm having an issue with my door ajar message flickering on and off almost constantly. I did plenty of searching and I can't seem to find anyone with my problem. I've used more than a fair share of WD40, PB Plaster, White Lithium... basically anything I can find in an aerosol can that isn't paint. No dice. Today I decided I would unplug each door one at a time to narrow it down (not just the sensor, the entire door). Well, I unplugged all 4 and the problem persists. I'm losing my mind here! Any pointers?
Thanks in advance.
2007 F-350 CC. I took a video yesterday. All doors were still plugged in, but the problem is the same. Doesn't matter if I'm parked, moving, or if the truck is off...
PhAyzoN is offline
post #2 of 8 Old 07-03-2013, 04:12 PM
Where the door locks into the door jam, the bar sometimes gets loose and will allow the door to move. If you can see swirls around the washer it is moving and will need to be tightened down. Hope this helps.
Sent from AutoGuide.com App
ian_hester06 is offline
post #3 of 8 Old 07-03-2013, 05:03 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 485 Post(s)
Garage
I believe the switch needs to ground the line to clear, so unplugging the doors will not narrow it down IIRC.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is online now
post #4 of 8 Old 07-03-2013, 06:14 PM Thread Starter
Wouldn't unplugging the doors result in the truck seeing either always open or always closed though? It still randomly flickers between the two.
Also, even when everything is plugged in, I can't make this happen. Pushing/pulling the doors doesn't do anything. I also pushed the latches closed with a screwdriver and wiggled the hell out of it, still nothing. Always happens completely on it's own.
PhAyzoN is offline
post #5 of 8 Old 07-04-2013, 07:27 AM
mhatlen's Avatar
Quoted: 485 Post(s)
Garage
I'm 98% sure that the door ajar comes from the circuit closing to ground. There is a switch in the latch that ties into the door ajar circuit. It's been a while now but I had to tie into it when I installed my Amp electric steps.
Try looking on their website for install wiring color codes for the year of your truck. Or if you can access the wiring on the truck through the "12Volt" website.
7" Icon/Carli Lift
Atlas40
post #6 of 8 Old 07-04-2013, 09:43 AM Thread Starter
Ok, I found the diagram on Amp's site. Looks like light green w/ yellow for the driver's door and pink w/ light blue for the other 3. Now, I'm fairly positive my problem isn't in the driver door because while the truck is off I never see the odometer come on unless I actually open the door. I did a bit of wire chasing and I believe the 3 pk/lb wires become 1 wire at the front driver's side. So, I decided to snip it. In theory, if there was a short between there and the door this would eliminate it. Aaaannndd my problem persists... Now I really don't know what to do.
PhAyzoN is offline
post #7 of 8 Old 07-04-2013, 04:39 PM
mhatlen's Avatar
Quoted: 485 Post(s)
Garage
Did you test the line for power ??
Then test it for continuity to ground. If it has continuity, strip the ends and touch ground/frame with both ends of the wire one at a time. If it is the home run to the signal it should simulate the door closed.
There is also a website 12volt I believe that has all kinds of wiring diagrams for pretty much everything. I know on DIYMA there is access to 12Volt for the wiring details. But most guys there use it for wiring up alarms and car stereo's etc. I believe the entire trucks wiring schematic is available too.
I think there is also a switch in the steering column that is also a part of the system for the key. Now that I think back I read a thread on FTE where a guy was having a similar issue and it was something around the ignition key under the column.
Try going onto that forum and do some searches, there are some pretty sharp guys over there. Bismic1 is a extremely sharp guy and a guy named blade1 has electrical diagrams for these trucks. Blade1 is into the electrical for whatever reason. Try to P/M him about your issue and see how you do.
Mark...
7" Icon/Carli Lift
Atlas40
post #8 of 8 Old 07-06-2013, 01:25 PM Thread Starter
Alright, I managed to determine it's a dash cluster problem. Swapped clusters with my truck at work and the problem moved over. Guess I'm sending it out for repair for the second time in a month
PhAyzoN is offline
