brandew batteries and alt... voltage question - Ford Powerstroke Diesel Forum
post #1 of 13 Old 06-29-2013, 04:33 AM Thread Starter
JustinOOO9's Avatar
Quoted: 524 Post(s)
Garage
so a few days ago my truck wouldn't start at friends house, found my batteries were at 8.8 volts and they were 5 yrs sold so figured they were just old... got 2 new batteries duralast 65, 850 cold crank amps and 1000 at 32 and above. then today truck barely started and then dash freaked out and died in middle of road... batteries at 4.5 volts.....so ripped out alt and had buddy tow me home and autozone tested the alt failed all 3 test... so got new one for like 130$ limited lifetime warranty 100amp reman. and i put the batteries pid on my edge cs insight and its only read 13/4 for about 5min and now it seems to peak at 12.6 and low 12.1... is my alt not working properly or did my new batteries just bite the dust from me not knowing about bad alt?
I dnt wanna kill my inject, or ficm i cant afford it after $400 in batteries and alt in 4 days.
also how can i test my alt at home? autzone ran the test and it got good on all 3 test.
thanks for reading.
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
post #2 of 13 Old 06-29-2013, 04:34 AM Thread Starter
JustinOOO9's Avatar
Quoted: 524 Post(s)
Garage
noticed they had a dual alt that said they were 135amps but the dealer said they didn't know if they would fit and auto stores locally didn't know or have any in stock is my reason for buying the 100amp reman,
Justin,
post #3 of 13 Old 06-29-2013, 05:44 AM
MrOneEyedBoh's Avatar
Quoted: 13 Post(s)
Feedback Score: 11 reviews
Damage on the ficm and injectors could have already happened... I know the ficm is super sensitive.
MrOneEyedBoh is offline
post #4 of 13 Old 06-29-2013, 07:41 AM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 485 Post(s)
Garage
Yea One eye is right there, I started my truck the other day with a low battery and noticed it cranked over at 8.8 volts. Since that day my ficm has been going down to 45 volts at first after starting then creeps back to 48 volts. Not doing it all the time but I am sure I de soldered one of the resistors in the ficm, I think however lately been seeing 47 as it's lowest time will tell.
That being said take a look at your ficm power and see where it's at. My old OEM alt did exactly what you are seeing with that reman unit. OEM is 110 amps I think regardless they are underpowered. I put in a 190 amp alt from DC Power and there is a huge difference. The lowest I see it go is 13.4 so the truck has much more voltage to work with.
Keep a eye on ficm voltage and your cranking voltages should stay 10.6 and above for a good system.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is offline
post #5 of 13 Old 06-29-2013, 07:55 AM
Term3's Avatar
Quoted: 2 Post(s)
A 100 amp alternator is not near big enough for our trucks IMO. I suggest upgrading your cables to at least 2/0, cleaning your grounds down to bare metal and using conductive grease on them. I had a 1/2 volt improvement just by upgrading my cables. My DC Power alternator stays between 12.6 and 12.8 even when I fire up my six Hella off-road 100 watt lights.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #6 of 13 Old 06-29-2013, 03:46 PM
mhatlen's Avatar
Quoted: 485 Post(s)
Garage
Agreed,
140 amps is really the minimum these trucks should have.
Have heard that some are using the 6G frame 130 amp alt and that one may be fine because of the higher cutoff voltage regulator in it.
These cheesy ones the 6.0 comes with are just bad news. I did watch mine charging at 12.1 and 12.2 volts and that's not enough especially if you are using a AGM battery. It will never top it off.
Get a DC Power 185 amp alt and your problems will be over. Once you get it take back the alt you already purchased.
I think the DC Power alt is around $325.00
7" Icon/Carli Lift
Atlas40
mhatlen is offline
post #7 of 13 Old 06-29-2013, 07:40 PM
Snake's Avatar
Quoted: 46 Post(s)
Originally Posted by mhatlen View Post
Agreed,
Agreed
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
post #8 of 13 Old 06-30-2013, 09:23 PM Thread Starter
JustinOOO9's Avatar
Quoted: 524 Post(s)
Garage
My FICM has been around 46-47.5 volts strong since i bought it like maybe 6 or so months ago. I think money has been a thing. after the headgaskets, oil cooler, egr delete, blue spring, gauges, exhaust,all sorts of pipes and dummys for hpop and many other parts just to get it running reliably... I replaced the batteries and now the volts have been around 13 while driving. so im praying it work. I just didn't have 325$ for a higher amp alt but Im kinda wishing i went with it anyways.
thanks for the help the starts got better within lats 2 days so have volts.
i gotta save up more now but you think the ficmrepair.com standard service would be good enough? I can't justify anymore major investments in my truck been over 5k so far inlast 6 months....
Justin,
post #9 of 13 Old 07-01-2013, 08:43 AM
Term3's Avatar
Quoted: 2 Post(s)
You what they say, "You can pay me little now or pay me a lot later." Until you can afford a higher amp alternator personally I'd use a tuner to set the idle up higher hoping it will help keep the volts up right after start up.
Term3 is offline
post #10 of 13 Old 07-02-2013, 12:33 PM
Island Dweller
Qholic's Avatar
Quoted: 57 Post(s)
Advance auto has a 140 amp alternator it is the top alternator for a two alternator setup it's plug and play for single alt truck.
sent from my Samsung S4
Shawn
2007 F-350 King Ranch FX4 LB Tow Boss DRW
SCT LiveWire, Atlas 80, WPE tunes, Blue Spring, Holders 175/30 injectors, KC Turbos Stage 2, Magnaflow Dual Tip 5", AMSOIL BMK-21, PMM Coolant Filter, Zoodad MOD, CCV MOD, AFE Pro Dry S OER Filter, Final Charge ELC, 08 style mirrors, SAP Diesel DD Solenoid, Derale Transmission Pan, Mishi CAC Tube and Boots, High Idle Mod, more to come..,
Qholic is offline
