Fog Light Problems - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-22-2013, 09:25 PM Thread Starter
USAFBowman's Avatar
Fog Light Problems
Hey guys I have a problem with my fog lights, they came stock on the truck. I recently upgraded headlights to Halo/HIDs. The lights will not work now. My indicator on the switch comes on sometimes, sometimes I need to play with it to get it to stay lit. I have trouble shot to the extent that i could and now I'm stuck. The wiring diagram said that there is a fog light relay; wheres this located? Or could my switch possibly be the problem >.< Thanks guys.
USAFBowman is offline
post #2 of 10 Old 06-23-2013, 02:26 AM
Island Dweller
Qholic's Avatar
Quoted: 57 Post(s)
The fog light relay is part of the Central Junction Box aka fuse panel that is inside the truck and is not a user-serviceable part. Sounds like to me if you have to play with the switch to get them to light up, that would be the first thing to check.
Shawn
2007 F-350 King Ranch FX4 LB Tow Boss DRW
SCT LiveWire, Atlas 80, WPE tunes, Blue Spring, Holders 175/30 injectors, KC Turbos Stage 2, Magnaflow Dual Tip 5", AMSOIL BMK-21, PMM Coolant Filter, Zoodad MOD, CCV MOD, AFE Pro Dry S OER Filter, Final Charge ELC, 08 style mirrors, SAP Diesel DD Solenoid, Derale Transmission Pan, Mishi CAC Tube and Boots, High Idle Mod, more to come..,
Qholic is offline
post #3 of 10 Old 06-23-2013, 08:05 AM Thread Starter
USAFBowman's Avatar
I see a fuse labeled for fog lights, but no relay. Do you know which relay the foggiest run through?
post #4 of 10 Old 06-23-2013, 08:15 AM
Island Dweller
Qholic's Avatar
Quoted: 57 Post(s)
My understanding is that it is part of the fuse box so your not going to see it directly.
Shawn
Qholic is offline
post #5 of 10 Old 06-23-2013, 08:18 AM
ZMANN's Avatar
Quoted: 1347 Post(s)
do u have an owners manual with fuse and relay locations ??
We Miss you Ronnie
ZMANN is offline
post #6 of 10 Old 06-23-2013, 08:39 AM Thread Starter
USAFBowman's Avatar
Yes my owners manual has the fuse names and locations.
So if it is a part of the box how would someone replace it?
post #7 of 10 Old 06-23-2013, 09:10 AM
Island Dweller
Qholic's Avatar
Quoted: 57 Post(s)
I guess the point is you would have to replace the whole fuse box. Like I said I would start at the switch level.
Shawn
Qholic is offline
post #8 of 10 Old 06-23-2013, 02:14 PM Thread Starter
USAFBowman's Avatar
Would it be reasonable to just skip the relay? The way I see it is the relay was only placed in there to shut them off when hi beams come on.... With the fog light mod it gets rid of that.... So should I be okay with just cutting the wire from the switch and the wire to the actual fog lights and splicing them together?
The switch is good because my lights in my bumper are run off the wire out of the switch but before the relay for the fogs.
post #9 of 10 Old 06-24-2013, 06:12 AM
Island Dweller
Qholic's Avatar
Quoted: 57 Post(s)
I would do the fog light mod; fixes your issue and does a good mod at the same time.
sent from my Samsung S4
Shawn
Qholic is offline
post #10 of 10 Old 06-24-2013, 06:20 AM
Lilfarmrboy's Avatar
I vaguely remember a post on here over a year ago where another ORG member was having a similar issue. Turned out that he needed to add an extra wire because of his new HID lights. Not saying this is the cure, just saying maybe do a check on past post. I really have a hard time believing that everything worked fine up to the HID install and now its a switch or fuse box issue.
Lilfarmrboy is offline
