06 Wiring - Ford Powerstroke Diesel Forum
post #1 of 2 Old 06-15-2013, 10:09 AM Thread Starter
willislawns's Avatar
06 Wiring
I am adding an amp to my stock stereo and new speakers. I have a 2006 SD and I need the wiring diagram. I have not yet pulled the dash. Any help would be great.
2006 F250 CC 4X4
STOCK (EGR Delete)
133k and counting
8'2" Boss V
6 way strobes
Blue spring upgrade
5" after down pipe 6" tip no muffler
Replaced fog lights with led bar
willislawns is offline
post #2 of 2 Old 06-17-2013, 12:01 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 449 Post(s)
Garage
Stereo options
Depending on how far you want to go with this the best way to do it is to run new speaker wires as well as a dedicated power line for the amplifier. Now if you are not planning on upgrading the stereo H/U there are adapter plugs available at Crutchfield.
Not sure how far they go for powering up a amp etc. Look them up online and see if there is a plug adapter for the application. I am sure you will have to bring in a power supply for it but there should be a plug assembly for the speakers that will connect to the amp outputs.
Me I strip the interior down to the sheet metal and start from scratch.
A little food for thought.............gotta be a easier way
I have a Nak CD700II that is going up for sale on ebay but its not a cheap unit.
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
