Adding reverse lights ? - Ford Powerstroke Diesel Forum
post #1 of 33 Old 06-14-2013, 11:41 AM Thread Starter
thumper280zx's Avatar
Ok guys I have read almost every post in every category about adding reverse lights. I even went to a local 4x4 shop and they confused me more. I want to wire the lights into the reverse lights but also to my up fitter switch. I know I need a diode so I don't back feed the system but where do I put it. I can't find a diagram or anything. Someone please help. A quick sketch would be great even if its on a napkin lol. I'm thinking I need to put it between the light and where I splice into the reverse light harness. Is this correct or do I need two diodes? One for both systems.
Sent from AutoGuide.com App
06 F350 King Ranch
egr delete, coolant filter, sct tuner more to come soon
thumper280zx is offline
post #2 of 33 Old 06-16-2013, 07:42 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 448 Post(s)
Garage
Get yourself a continuous duty solenoid at a auto parts store. It will look a lot like the older Ford fender mount ones but these use less coil voltage to close the contacts.
They will have 2 terminal posts one in and one out.
One of those terminal posts go to your new lights.
Other terminal post goes to the main power wire in the trailer plug with a fuse of proper size. I used 55 watt lights and a 20 amp fuse IIRC.
Then you have a positive control terminal that you will connect to one of your reverse light hot wires.
And one other terminal for the ground.
When you put it in reverse the small lights will power the solenoid and on come the good lights. I love the lighting I now have they work great. Bought a pair at Auto Zone for $30.00 and the solenoid was $25.00. Well worth it.
I don't recommend the upfitter because its too easy to forget they are on and if your not backing up what's the use lol.
It can be done with a separate relay or C/D solenoid. Not familiar with using diodes that can move that amount of wattage.
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
post #3 of 33 Old 06-16-2013, 07:47 PM Thread Starter
Yeah I mainly want them to back up and already have them hooked up but I want a switch so when I'm hooking up a trailer or or changing a flat on the trailer etc etc.
And what is the solenoid for. Does it give the light more power
06 F350 King Ranch
post #4 of 33 Old 06-16-2013, 08:06 PM
mhatlen's Avatar
Quoted: 448 Post(s)
Garage
The solenoid if what takes the load. You can run a wire from the battery all the way back to your new lights but the only way you can power them is through another power supply. In other words the small wire now powering your reverse lights will not power anything with any size to it.
The solenoid gives you a switching point to power up using small amperage to enable it to happen. The trailer plugs main power line is plenty big enough for 55 watt lights.
Atlas40
BPD Waterpump
Fabtech Radius Arms
mhatlen is offline
post #5 of 33 Old 06-16-2013, 08:10 PM
mhatlen's Avatar
Quoted: 448 Post(s)
Garage
A cont. duty solenoid is basically a relay with a 12volt control coil. any rated 12v relay will work fine, problem with most of them is they will not hold up to the exterior location. c/d solenoids are automotive based and will hold up under a truck. Waterproof.
Atlas40
BPD Waterpump
Fabtech Radius Arms
mhatlen is offline
post #6 of 33 Old 06-16-2013, 08:30 PM Thread Starter
Thanks for all the help. I have them wired to the trailer wiring harness right now cause i dont have any trailers that have reverse lights. so I will add the solenoid in tomorrow
06 F350 King Ranch
post #7 of 33 Old 06-16-2013, 08:57 PM
05_PSD_Erik's Avatar
I will draw you up a schematic shortly and post a link to the picture.... give me a few
EDIT:
The relay pictured and the numbers used are a standard 30A automotive relay you can pick up in the light section of any parts store.
The diode needs to placed in the direction such that it blocks electrical path going from the upfitter to the factory lights, install it backwards and the lights will only work when you flip your upfitter and it will also cause the factory back-up lights to illuminate. You can pick up a basic diode at radio shack for pennies, I recommend when you install the diode, do it close to the taillight and solder and heat shrink the connection for protection from the elements.
Your constant 12V can be picked up from the trailer plug harness, there should be a full time (any time the key is on, at least) 12V there you can use, and I recommend a fuse be placed between the constant 12V and the relay, just in case.
What you are doing is powering the lights from that constant 12V through the relay, all the back up lights and upfitter power is doing is picking up the coil inside the relay. That relay probably only draws tenths (0.16 or so) of an amp, so no worries of overloading the factory back up lights.
I hope this is clear and helps you out.
2009 Subaru WRX Premium
Type RS BOV
CAI
Muffler Delete
Had to park it with some real diesel muscle....
05_PSD_Erik is offline
post #8 of 33 Old 06-16-2013, 09:04 PM Thread Starter
Thanks you i appreciate it a lot
06 F350 King Ranch
post #9 of 33 Old 06-16-2013, 09:58 PM Thread Starter
EDIT:
Thanks again it helps out a whole lot. One last question I have is does the factory up fitter switch already have 12v power to it? And if so do I need to run a constant 12v power to it. Don't want to beat a dead dog and am thankful for all the help so if constant 12v is needed just say yes lol
06 F350 King Ranch
post #10 of 33 Old 06-17-2013, 11:17 AM
mhatlen's Avatar
Quoted: 448 Post(s)
Garage
Yes look behind your glove box up high and you will see all the wires for the upfitter outputs. There is a little fuse panel there pull the lid and check it out.
They are all relay powered and there are of different amperages forget their ratings but the fuses are in there too and you will figure it out. You are not pulling many amps for the lights. The wires are just sitting there waiting for you to grab and go.
Yes good illustration, you have the typical relay there I still recommend a cont/duty solenoid here is a pic of mine. I mounted it to the frame at rear bumper and you can blast it with a pressure washer if you wish to.
No problem on the questions, let me know if you have anymore.
Mark.......
Atlas40
BPD Waterpump
Fabtech Radius Arms
mhatlen is offline
