Led replacement bulb? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 06-10-2013, 02:43 PM Thread Starter
pudil45's Avatar
Send a message via MSN to pudil45
Looking for a good led replacement for I think 3157 bulb in the flatbed truck lights.Led replacement bulb?-imageuploadedbyautoguide1370900632.333002.jpg
Sent from AutoGuide.com App
2001 F 350 DRW
7.3 Powerstroke
4 inch downpipe to 5 inch mitre cut stacks
Southbend Dynamax clutch
DP Tuner
2006 F-450 6.0
Bone stock
Whelen Justice Wecan
Aluminum 11' bed with folding sides
pudil45 is offline
post #2 of 14 Old 06-10-2013, 02:59 PM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
Definitely a good bulb is the RED PLATINUM 21 LED BLINKER BRAKE LIGHT BULBS 3157 3156 4157 | 1 PAIR - Red LED - 3157 - 3156 LED - Bulb #
I use them in my tail lights, they are very bright and have a great difference in contrast between the tail light intensity and the brake light intensity which some led bulbs don't have.
Before you order leds, take out one of your stock bulbs to make sure it is a 3157. It is possible that your tail lights use the 1157 bulbs.
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #3 of 14 Old 06-10-2013, 03:12 PM Thread Starter
pudil45's Avatar
They don't look like just a dot right? I've seen some LEDs that are a penny size dot because the light doesn't spread out. And does yours flash fast or normal now?
2001 F 350 DRW
7.3 Powerstroke
DP Tuner
2006 F-450 6.0
Bone stock
pudil45 is offline
post #4 of 14 Old 06-10-2013, 03:30 PM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
No, these don't just light up a round dot. They shine all directions to light up the entire lens.
To make them flash at the correct speed, just replace your flasher with an electronic flasher which you can get at almost any auto parts store.
Here is a video of them in my tail light housings:
GregsSD is offline
post #5 of 14 Old 06-10-2013, 04:01 PM Thread Starter
pudil45's Avatar
Cool. Thanks a lot. I've got a Whelen lightbar with led stop tail turn but incandescent truck lights. Doesn't look that great
2001 F 350 DRW
7.3 Powerstroke
DP Tuner
2006 F-450 6.0
Bone stock
pudil45 is offline
post #6 of 14 Old 06-11-2013, 04:27 AM Thread Starter
pudil45's Avatar
Think it's standard or cv?
2001 F 350 DRW
7.3 Powerstroke
DP Tuner
2006 F-450 6.0
Bone stock
pudil45 is offline
post #7 of 14 Old 06-11-2013, 11:25 AM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
You will need the standard style.
GregsSD is offline
post #8 of 14 Old 06-11-2013, 08:17 PM
Superbrightleds.com. Great resource.
Jetway is offline
post #9 of 14 Old 06-20-2013, 07:43 PM
PowerStrokedRedneck's Avatar
I have SuperBrightLEDs in my car and Excursion. I live them. Very bright. Fills the whole housing with light not just the dot. I've had them in my at for probably 50k miles and about 4 years with no problems.
If I'm not mistaken your flat bed lights should have 1156 bulbs.
PowerStrokedRedneck is offline
post #10 of 14 Old 07-17-2013, 12:43 AM
Semper Fi
TClev's Avatar
Quoted: 2 Post(s)
Garage
I just ordered LED light replacements for every exterior light from superbrightleds.com. I haven't seen a complete list of part numbers and quantities for this project all from one place. If everything goes according to plan and all of these bulbs fit and work correctly, I will do a write up of the information to aid everyone else who is looking to do this project.
Tony Clevinger
06 F250 6.0L Auto Trans - 124,000 mi
Lariat FX4 CCSB
Toyo Open Country 275/65R20
Bilstein 5100s
Edge Evo CTS
Deleted by Scheid Diesel - Lafayette, IN
Bulletproofed by Reckless Diesel - Dallas, TX
CAT EC-1
Rotella T6
XDP Coolant Filtration
Blue Spring
Turbo Oil Feed/Drain Update
Injen Power-Flow Intake
MBRP 5" Stainless TB
Riff Raff Hot Side CAC Boots
Upfitter SEIC
TClev is offline
