dual 12" sub enclosure. what subs to get? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-02-2013, 06:00 PM Thread Starter
just bought a dual 12" enclosure for behind my rear seat. I have 2 alpine type R's that I planned on installing, but sure enough they are too deep. I have a 600w alpine amp im going to be using. What type of shallow Subs are going to sound best in here?
what are you guys using?
Im looking to buy something online, so some suggestions would be helpful!
thanks guys
icebergc90 is offline
post #2 of 4 Old 06-02-2013, 07:18 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 440 Post(s)
Garage
How much speaker is hanging out? Can you cut some circular rings to space it out to get magnet off the rear of the enclosure ?
I am a huge JL Audio fan myself, one thing you want to do is match the enclosure square footage to the speaker. You can alter it a bit with the use of moly foam pillow stuffing to make up for enclosures that are under sized. It's harder to correct when box exceeds the square footage of the woofer not too likely going to be the case here.
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
post #3 of 4 Old 06-02-2013, 07:24 PM
05f250harley's Avatar
i had two rockford fosgate 10'' r2s but after two sets cracking i wont buy them again. i plan on getting two jl 10'' tw3. Im not sure about a box yet.
05 Harley Davison Edition Arp head studs, SCT livewire TS, 03 turbo, PMM egr delete, PMM coolant filter, afe cai, blue spring, 6.4 banjo bolts, updated stc, standpipes and dummy plugs, 4" exhaust with no cat and no muffler
03 RCSB 205/100 warren injectors, BW s366, Lots of supporting mods to come
05f250harley is offline
post #4 of 4 Old 06-02-2013, 07:29 PM
ZMANN's Avatar
Quoted: 1334 Post(s)
jl's are nice and $$$
I went with a Shallow 12" Rockford on recommendation from the box builder(ported)
and I run a full size 10" in a sealed box
both behind the seat
so far I have really pushed the 12" with no issues
We Miss you Ronnie
ZMANN is online now
