Anyone have a pioneer AVH series head unit? I need video converting help. - Ford Powerstroke Diesel Forum
post #1 of 17 Old 05-28-2013, 09:38 AM Thread Starter
MrOneEyedBoh's Avatar
Quoted: 13 Post(s)
Feedback Score: 11 reviews
I have some DVDs I was looking at converting on a USB to watch on the head unit ( or maybe an external HD ) What I was wondering is what format/program did you use to convert your dvds? What are you using for holding your library? USB drive, USB HD etc. I have the AVH-x4500bt
MrOneEyedBoh is online now
post #2 of 17 Old 05-28-2013, 10:10 AM
Quoted: 3 Post(s)
i use anyvideoconverter
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #3 of 17 Old 05-28-2013, 10:34 AM Thread Starter
Quoted: 13 Post(s)
What format? what screen ratio? how do you play the videos back? Usb stick?
post #4 of 17 Old 05-28-2013, 11:21 AM
snafu!'s Avatar
Looking at getting the the avh-8500bhs. Would also like to know if the usb port allows an external hard drive.
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
post #5 of 17 Old 05-28-2013, 11:39 AM
alaskan155's Avatar
Quoted: 60 Post(s)
i don't have dvd playback on my pioneer but i run a 40gig usb hard drive for music on it.
it formatted in fat32(windows xp+ default is ntfs)
if i did it again i would run a usb flash drive, smaller and less prone to breakage, the last 6 years or so have been abusive to my 2.5" laptop hard drive between the temperature changes a vehicle and the shock of it bouncing in the glove box. there are less mechanical parts in a usb flash drive.
there are days my hard drive doesn't want to boot either due to cold or heat.
btw my pioneer is a old deh-4000
2002 F250 7.3/JW Tow master 4r100 210k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #6 of 17 Old 05-28-2013, 04:41 PM Thread Starter
Quoted: 13 Post(s)
there are no mechanical parts lol. I was thinking USB too. Pretty cheap for a 32.. You can get a few of them and be good to go
post #7 of 17 Old 05-31-2013, 06:21 PM
amdriven2liv's Avatar
Quoted: 4 Post(s)
I'm currently using a 8 GB thumb drive, works great. I just have the USB cord on top of my CB and just leave it plugged in. And the Mixtraxx does a good job.
pioneer avh-x5500bhs
2004 F350 6.0L CC LB 4x4 King Ranch
amdriven2liv is offline
post #8 of 17 Old 05-31-2013, 09:38 PM
Quoted: 3 Post(s)
i just use my ipod, load it up with a bunch of videos and go.
2000 DRW CC 7.3
post #9 of 17 Old 06-02-2013, 01:13 PM Thread Starter
Quoted: 13 Post(s)
Yeah but how? Do you have to use itunes? I have an ipod but I dont really use it. I usually use media monkey or I did when I used to use it lol
post #10 of 17 Old 06-02-2013, 10:53 PM
snafu!'s Avatar
It can read Divx, wmv, and mp4 so pretty much any way you compress a movie the avh can read it from a usb drive or hard drive. Currently I'm using Aiseesoft to compress movies down to a more manageable size, it works ok but I'm always looking for better software.
Cameron
Warren 285/100
ODAWG ported intake
Built Trans
Water/Meth
snafu! is offline
