keyless entry problems - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-26-2013, 10:25 AM Thread Starter
sprksonu's Avatar
hey guys i am having troubles with my factory keyless entry system on my 05 ccsb 250 4x4. all of the sudden my key fob stopped working so i replaced the battery on the key fob and still no go, went to checker and tested the key fob on their tester and it showed good so i figured maybe it needed to be re-programed i cycled the key 8 times and nothing happens? the key pad on my door still works? any help would be greatly appreciated thx
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #2 of 8 Old 05-26-2013, 10:30 AM
ZMANN's Avatar
Quoted: 1900 Post(s)
checker can test the RF functionality of a FOB ?
We Miss you Ronnie
6.0 flush pdf
ZMANN is online now
post #3 of 8 Old 05-26-2013, 10:35 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Mine does that every once in a while. Shut your doors and then hold the lock and unlock buttons on the remote for 5 seconds and then see if it works. Works for me.
dhanna6powerstroke is offline
post #4 of 8 Old 05-26-2013, 10:39 AM Thread Starter
sprksonu's Avatar
yep the one by my house can
sprksonu is offline
post #5 of 8 Old 05-26-2013, 10:45 AM Thread Starter
sprksonu's Avatar
tried holding the unlock lock button and no go?
sprksonu is offline
post #6 of 8 Old 05-26-2013, 11:11 AM Thread Starter
sprksonu's Avatar
and now the keypad on the door stopped working???
sprksonu is offline
post #7 of 8 Old 05-26-2013, 11:22 AM Thread Starter
sprksonu's Avatar
ok figured it out on some 05 models you have to do the key on and off 8 times in ten seconds then hit the unlock button on the door panel then it goes into program mode, works like a charm now
sprksonu is offline
post #8 of 8 Old 05-26-2013, 12:02 PM
ZMANN's Avatar
cool
I have one from a Tahoe that just died and a battery or program doesn't seem to take
We Miss you Ronnie
6.0 flush pdf
ZMANN is online now
