JVC dimmer - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-23-2013, 12:06 PM Thread Starter
JVC dimmer
What wire in the 2003 harness needs to be connected to my JVC to dim the display when the lights are on? I used the plug in from Best Buy that plugged into the Ford harness, then you connect your speakers, power etc to the deck pigtail. Everything works fine except the auto dimmer control.
Sent from my LG-VS700 using AutoGuide.Com Free App
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #2 of 8 Old 05-30-2013, 10:25 AM Thread Starter
Nobody knows what wires to connect to make your aftermarket deck illuminate with your dash,
Karls03 is offline
post #3 of 8 Old 05-30-2013, 08:26 PM
Quoted: 2 Post(s)
To the best of my knowledge it will be an orange or orange w/white stripe wire coming from the best buy adapter harness. The adapter harnesses usually match color for color to the aftermarket radio pigtail.
2007 F250 Lariat FX4 CCSB
200,000+ Miles
SCT Livewire TS
Innovative Xtreme Street
Barder Stg 1.5
Arp Studs, Sinister EGR Delete
cudakid03 is offline
post #4 of 8 Old 05-30-2013, 08:34 PM
ZMANN's Avatar
Quoted: 1343 Post(s)
the 12volt.com has the colors
Radio 12v lt. green/purple + radio harness
Radio Ground black/lt. green - radio harness
Radio Ignition pink + radio harness
Radio Illumination lt. blue/red (dimmer) + radio harness
Factory Amp Turn-on
Power Antenna
LF Speaker +/- org/lt. grn - lt. blue/wht +,- radio harness
RF Speaker +/- wht/lt. grn - green/orange +,- radio harness
LR Speaker +/- gray/lt. blue - tan/yellow +,- radio harness
RR Speaker +/- orange/red - brown/pink +,- radio harness
We Miss you Ronnie
ZMANN is offline
post #5 of 8 Old 05-30-2013, 08:37 PM Thread Starter
All of the wires were connected, even wired in an amp, but no dimmer when the lights come on. The instructions were just this side of useless.
This whole thing probably has to do with the fact that this JVC uses day, night, and auto.
Karls03 is offline
post #6 of 8 Old 05-30-2013, 08:40 PM Thread Starter
I'll have to look into this. It will be an excuse to get a better mount, I'm not too crazy about that el cheapo one I bought.
Karls03 is offline
post #7 of 8 Old 05-30-2013, 08:44 PM
Quoted: 2 Post(s)
He is using an aftermarket harness that should use the standardized color code. In other words the Lt. Blue/red wire in the ford plug should connect to an orange wire in the best buy plug which will get spliced to the orange wire of the JVC head unit. Hope that makes sense.
200,000+ Miles
SCT Livewire TS
Barder Stg 1.5
post #8 of 8 Old 05-30-2013, 08:54 PM Thread Starter
Everything hooked up, the lights come on, but they don't dim with the headlights. I'll double check that said wires from the JVC go to the correct wire in the plug and play harness.
Either way, I appreciate the inputs, I'll get to it this weekend.
Karls03 is offline
