Recommendation on LED tails **Instead of RECON** - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-22-2013, 05:51 PM Thread Starter
Hey guys, looking for a good recommendation on tails and a third brake light (LED). I had RECON and they failed after 7 months. For the price I paid I expected much more. And oh yeah, their customer service was horrible. All they did was offer to sell me more lights
Any help is appreciated!!
2006 F-350 FX4 sc/sb 6.0
4" turbo back MBRP no cat
Sinister EGR delete
Sinister coolant filter
SCT tunes by Mike @ Sinister
New oil cooler (5/2013 @ 50k)
Boss Plow
Hi-idle mod
Insight CS
Sound off 1400's
Rigid Duallys
fffowler is offline
post #2 of 8 Old 05-22-2013, 10:49 PM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
For tail lights, you could swap in some 2008 or newer ones and put in some led bulbs! I did this and it looks great:
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #3 of 8 Old 05-23-2013, 04:30 AM Thread Starter
2005 Superduty with 2010 taillights and LED bulbs - YouTube
Thanks Greg. Did you replace your flasher? Somewhere around the radio correct? Also noticed in your sig dual color front turns? What's the deal with those?
Sinister EGR delete
Boss Plow
Hi-idle mod
Insight CS
Sound off 1400's
Rigid Duallys
fffowler is offline
post #4 of 8 Old 05-23-2013, 09:38 AM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
The flasher is simple to replace, just pick up an "EP-27 Electronic" flasher at an auto parts store.
If you have the drivers side glovebox, just squeeze the tabs together on it so that you can lower it out of the way, then reach in the opening and the flasher is just behind and above the opening.
The dual color front turn signals (switchbacks) give you a white parking light, but when you activate the turn signals they change to amber and flash!
Here is a video of mine:
GregsSD is offline
post #5 of 8 Old 05-23-2013, 10:00 AM
I found a red LED bulb at the auto parts store that plugged right into the receptical on my 2009 Vulcan, is there any reason that wouldn't work in my 2003 tail light housing? It does the dimmer tail light and the brighter blinker like the incandescent bulb did, just mucho brightero.
Sent from my LG-VS700 using AutoGuide.Com Free App
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #6 of 8 Old 05-23-2013, 04:14 PM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
It should work fine! You need to change your flasher to an electronic one so that the led bulbs will still flash at the correct speed.
GregsSD is offline
post #7 of 8 Old 06-20-2013, 08:02 PM
PowerStrokedRedneck's Avatar
I would use an EP-27L flasher. It's the same as mentioned above but it clicks louder.
Sent from AutoGuide.com App
PowerStrokedRedneck is offline
post #8 of 8 Old 06-29-2013, 02:18 AM
lopealle's Avatar
That's awesome. I think I may add this to my list of things to do.
lopealle is offline
Tags
brake lights , led , lights , tail lights
