dual alternators= dual volt meters - Ford Powerstroke Diesel Forum
post #1 of 11 Old 05-22-2013, 04:06 PM Thread Starter
so i bought a 2005 f350 lariate dually. and it has two alternators. and i was curious if there was a way to hook up a volt meter to each of them so i can just replace one when one goes bad instead of replacing both of them because both of them stop working. so this is my first ford so i dont know crap about them any help would be awsome thanks
jeremy
05gitsumexchevyguy86 is offline
post #2 of 11 Old 05-22-2013, 04:54 PM
Quoted: 58 Post(s)
jeremy
My truck also has dual alts. Not sure why you would need to replace both alts if one fails. The PCM controls when each alternator runs. I recently had to replace the lower one and ran with just the upper for a week or so. No issues and no check engine light.
Not sure how you could isolate the two charge circuits such that you could get independent voltage readings. I suppose one could install ammeters on each one and the presence of current output would indicate whether it is charging or not.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDCV Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Radius Arms
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #3 of 11 Old 05-25-2013, 08:43 AM Thread Starter
ya there has to be some way. i was talking to my friend and sometimes one goes bad and you dont know it and you run on ur other alternator till both batteries are drained and the alternators are both bad. so im going by that
post #4 of 11 Old 05-25-2013, 05:12 PM
JSchuricht's Avatar
Like stated above, you would need a ammeter. A voltmeter measures voltage which will be about the same on both alternators because they are connected together. A ammeter measures the current flow or drain. You will need a shunt style meter, basically cut each alternator wire and put a shunt in the middle. The meter will hook to each side of the shunt and measure voltage differential which in turn shows up as amps.
JSchuricht is offline
post #5 of 11 Old 05-25-2013, 05:24 PM Thread Starter
ya i understand that. the right ammeter is $222 which makes this idea deff. not worth it
http://www.summitracing.com/parts/atm-6390/overview/
post #6 of 11 Old 05-25-2013, 05:31 PM
JSchuricht's Avatar
If you don't mind something a bit less fancy, try ebay. You will also need a shunt.
post #7 of 11 Old 05-26-2013, 05:15 AM Thread Starter
thanks , but am i being a lil far fetched with this idea?
post #8 of 11 Old 05-26-2013, 11:18 AM
jesilvas's Avatar
Quoted: 3 Post(s)
I would say just run it till one goes out, then keep only one working.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #9 of 11 Old 06-20-2013, 06:52 PM
PowerStrokedRedneck's Avatar
The only time you'll ever actually need both alternator is if your running something that take ALOT of amperage. Most all of the truck only have one alternator and they run just fine.
Sent from AutoGuide.com App
PowerStrokedRedneck is offline
post #10 of 11 Old 06-27-2013, 11:10 AM
jlmotox's Avatar
Couldn't you just disconnect one and check the voltage with the other one running? Then do the opposite for the other? Also most parts stores can check if they work by bringing it to them...
2005 F250 Lariet FX4 CC SB 6.0, 6" ProComp Stage2 Lift,17x9 ProComp wheels,35" ProComp xtreme AT's,Warn 12k winch w/hidden kit,Custom light bar w/4-8" ProComp,Pioneer double din Nav XM back up cam,10" kicker sub,1000w 5channel amp,15% tint, Truxedo bed cover,Firestone Bags,Airaid intake,4" turbo back MBRP exhaust,ARP headstuds
jlmotox is offline
