Power Windows and Radio don't work. - Ford Powerstroke Diesel Forum
post #1 of 2 Old 05-19-2013, 03:40 PM Thread Starter
As stated above my power windows and radio are not working. I was reconnecting my under hood lights wires as I had to cut them to remove my hood during my head stud install. While reconnecting the wires, there was a small arc when I reconnected the wires. I went to roll my window up to drive it and the window wouldn't roll up and my radio wouldn't turn on. I checked all fuses and none were blown, I also replaced the circuit breaker for the power windows but still no change. I am wondering if there is any other simple things I should check before taking it into the dealership to get it fixed. Thank you in advance.
powerstroke9403 is offline
post #2 of 2 Old 10-20-2013, 08:37 AM
LSSBoy's Avatar
It happened to me last week. Just after i hookd hp my new cab light. I solved the problem this morning. Under your dash remove the panel then the fuse cover. Check your "instrument cluster" fuse. I think there is 3 of 'em. On mine the 41 was blown. 10A. Replaced it with a new and works fine.
Hope it helps
LSSBoy is offline
Tags
electrical , fuse , power , radio , window
