What buttons will I lose? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 05-05-2013, 06:04 AM Thread Starter
Hemicbx's Avatar
Hey guys,
I have a decent Sony head unit & install kit laying around. I'm thinking about throwing it in the truck without hunting for a steering wheel button thing. But if I do this, what steering wheel buttons will I lose function of? Clearly the radio buttons will not work and I can deal with that. Will the cruise & HVAC buttons continue to work OK?
I ask this because I have a 90's Buick that I put a radio in and ALL steering wheel buttons passed through the radio so I lost HVAC and radio control.
The truck's a 2005 F350
Thanks in advance,
-Hemicbx
2005 F350 CCLB Dually 4x4 Lariat 6.0L
Fixes:
Coolant flushed & DieselSite coolant filter
Blue spring
New OC & STC upgrade
Turbo lube tubes upgraded
Insight CS
BPD EGR Cooler
Hemicbx is offline
post #2 of 10 Old 05-05-2013, 07:09 AM
Quoted: 2 Post(s)
What model unit is it? Some have features that let you keep functions.
Troy K.
2003 Ford F-250 6.slow w/240K
4" Turbo back exhaust
SCT X4
XDP coolant filter
Blue Spring
315/75 BFG MT's on American Racing rims
Leveled
5100's
And way more time and money invested than its worth
Turk.919 is offline
post #3 of 10 Old 05-05-2013, 11:57 AM Thread Starter
Hemicbx's Avatar
My sony does not have that feature.
It does have a remote, so I can live without the steering wheel buttons for the radio, but I have to have the HVAC & cruise buttons.
-Hemicbx
Fixes:
Blue spring
Insight CS
BPD EGR Cooler
Hemicbx is offline
post #4 of 10 Old 05-05-2013, 12:02 PM
Quoted: 2 Post(s)
Well, how good are you at electronics?
Troy K.
SCT X4
XDP coolant filter
Blue Spring
Leveled
5100's
Turk.919 is offline
post #5 of 10 Old 05-06-2013, 12:48 PM
pull the stock head unit and see what works.
drewmeister13 is offline
post #6 of 10 Old 05-06-2013, 12:59 PM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
My 2001 mercury mountaineer(Ford) had an aftermarket in it. i lost the radio controls obviously but i still had cruise and HVAC. Id imagine its the same since its the same steering wheel
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #7 of 10 Old 05-07-2013, 04:41 PM Thread Starter
Hemicbx's Avatar
I'll pull the stock unit out Saturday and see what we have working.
Fixes:
Blue spring
Insight CS
BPD EGR Cooler
Hemicbx is offline
post #8 of 10 Old 05-08-2013, 09:13 AM
The c/c and HVAC are on a different circuit and will not be affected if you remove the radio
2006 F250 PSD-Fabtech lift,King Coil overs,AMP steps,37's,some other bolt ons.
1965 Mustang Fastback-
Sound Decision Car Audio-MECP Certified
Ford Master Tech
iskwezm is offline
post #9 of 10 Old 06-18-2013, 04:34 PM Thread Starter
Hemicbx's Avatar
I just wanted to close this thread out with a final answer. Many have already said it; the other buttons continue to work just fine. Only the radio buttons do not.
Thanks to all those who chimed in.
I have considered buying one of the little adapter thingys to make them work through this radio, but I'm not sure I see the need.
I'm so glad I finally installed the new head unit. Even with stock speakers it sounds much better and I can charge/play my iPhone through the radio now.
-Hemicbx
Fixes:
Blue spring
Insight CS
BPD EGR Cooler
Hemicbx is offline
post #10 of 10 Old 06-18-2013, 05:04 PM
ZMANN's Avatar
Quoted: 1346 Post(s)
sorry I missed this earlier
I have done the swap and
agreed only the radio controls are lost it's not like some where the HU is the hub for multiple things and chimes
if someone wants to integrate the controls and has an applicable Head unit
a Metra Axxess AWSC can handle the integration better than the PAC unit IMHO
We Miss you Ronnie
ZMANN is offline
