cluster lights on my 06 - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-29-2013, 06:32 PM Thread Starter
hazard's Avatar
just wondering what bulbs to get for my 06 gauge cluster, i have one out, took it apart and though it was a #74 bulb but it appears to be smaller than that. the only other option at the parts house was a #37 bulb. can anyone tell me what the correct bulb is for my application?
Thanks,
Adam
2006 F-250 6.0L CCSB Lariat 4x4, ARP studs, SCT tunes by innovative diesel, Silverline 4" turbo back exhaust no cat no muffler! Upfitter switches w/high idle mod, Edge Insight monitor w/EGT probe, autometer fuel psi gauge, Zoodad mod with billet plate. Ford Updated fuel psi spring and banjos, RCD egr delete, Ford updated oil cooler and stc fitting, dieselsite cac boots and coolant filter.
1984 Mercedes Benz 300D Turbo Diesel, cold air intake.
"Run Hard, Dream Big"
hazard is offline
post #2 of 2 Old 04-30-2013, 07:21 PM
Quoted: 3 Post(s)
Oh, this game...
I played it, but I don't remember what the outcome was.
I do happen to have one of the twist-lock sockets and couple of #37 bulbs in my stash, and they do fit the socket.
I don't remember if the #37's were the ones the Ford parts guy gave me that were "close enough" though.
I believe that #74 and #37 are the same size (both T1-3/4, 5mm x 18mm), the difference between them is the #74 is supposed to be brighter than the #37.
Then there is the PC161... which is the bulb including socket combo.
I *think* the proper Ford part is 5F9Z-13B765-BA, but they want an arm and a leg for them (this is bulb + socket).
Please update the thread when you eventually figure it out.
Lee
ve7fet is offline
