Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Electronics Discussion
Old 02-12-2008, 10:40 AM
Amarillo_Powerstroker Amarillo_Powerstroker is offline
Compression Ignition Fool
12V Key ON Power Source
I'm in the process of installing some Nexus gauges from Raul @ Stealth Automotive in my '06 6.0 F250. Im trying to locate a 12V Key ON Power source for the gauge lighting. This power source has to be live only when the key is on and while the engine is cranking. Does anyone know of a wire color/location near the drivers side fuse box area off hand that I could use? The location that Autometer tells you to connect the gauge lighting is behind the headlight switch to the blue w/ red stripe wire, but it is only hot when the headlights/running lights are on. Thanks in Advance for your help... -Brad
Old 02-12-2008, 12:33 PM
SPL2K SPL2K is offline
red w/light green in the ignition harness by the steering column.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
