keyless entry - Ford Powerstroke Diesel Forum
post #1 of 12 Old 04-13-2013, 04:53 PM Thread Starter
willislawns's Avatar
keyless entry
where is the factory 5 digit code for the door key pad. owner manual says computer module. im new to 6.0 so please be specific. mines a 2006
2006 F250 CC 4X4
STOCK (EGR Delete)
133k and counting
8'2" Boss V
6 way strobes
Blue spring upgrade
5" after down pipe 6" tip no muffler
Replaced fog lights with led bar
willislawns is offline
post #2 of 12 Old 04-13-2013, 05:01 PM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
the code from the factory should be in your owners manual? If not you can go to ford and they can reset it for you for free.
tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #3 of 12 Old 04-13-2013, 05:08 PM
rdaffin's Avatar
Under the dash dead center is the computer for the alarm. It is mounted on the firewall on the inside and a pain in the butt to see. There is some sound deadening fuzzy stuff that you have to push aside. A mirror and a flashlight will be needed.
Sent from AutoGuide.com App
2004 CCSB 4x4, blue spring, SCT , 4" exhaust, Gearhead tunes, egr delete, ELC-1, Coolant filter, ARP Studs, CCV Mod, 6" lift, 35" Toyo A/T II.
rdaffin is offline
post #4 of 12 Old 04-13-2013, 05:10 PM
rdaffin's Avatar
Sorry. There is a decal on it that has the code. It is in one corner of the decal. Only five digit number on it.
rdaffin is offline
post #5 of 12 Old 04-14-2013, 07:33 AM
soccerman's Avatar
The numbers are bigger so if you see a decal and you have to squint to see it because it's too small of writing, then a chance you are looking at the wrong thing.
2006 F350 Lariat
TowBoss Package
Front & Rear Camera
High Idle Mod
Rear Flood Lights
58V Swamps FICM
Remote Start
Straight Pipe
HID Head Lights
BD Heavy Duty EGR Cooler
Blue Spring Upgrade
STC fitting Upgrade
New IPR
Standpipes/Dummy Plugs
Lockpick
soccerman is offline
post #6 of 12 Old 04-14-2013, 07:46 AM
Winning DUHHH
Young-SC-Owner's Avatar
Quoted: 8 Post(s)
Pull the radio, that helps
99.5 F-350 SRW Short Bed, Ex Cab.
6637
Wicked Wheel'd,
Southbend
Autometer - Boost, Pyro
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
7 year Veteran with SBFD
Airframe and Powerplant Mechanic
Head Marine Technician
Dont Tread on Me
Young-SC-Owner is offline
post #7 of 12 Old 04-14-2013, 08:19 AM
majek5's Avatar
tom
The two dealers I called said they charge $50 or $60 to reset the code.
2006 F350 CCLB KR FX4
stock...
majek5 is offline
post #8 of 12 Old 04-14-2013, 08:38 AM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
Thats bull! It takes them literally 5 minutes to reset it and to put in your code you want... They did mine for free.
Tom
Other Rides
tkobes43 is offline
post #9 of 12 Old 04-14-2013, 09:55 AM
majek5's Avatar
Tom
I totally agree! Thats why I'm still using the one the PO gave me when I called him. It's not worth $50 to me to change it!
stock...
majek5 is offline
post #10 of 12 Old 04-14-2013, 12:15 PM Thread Starter
Thanks I will be going out there to check. It was after 5pm on a sat and all dealers were closed.
2006 F250 CC 4X4
STOCK (EGR Delete)
133k and counting
8'2" Boss V
6 way strobes
Blue spring upgrade
