ScanGauge and TPS question - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-13-2013, 08:28 AM Thread Starter
Soledad's Avatar
Garage
Yesterday I programmed in TP1, TPA, TPC and TPD into my ScanGuage however none of them worked. I thought maybe I had entered a wrong digit in them so I re-programmed them again and still got the same result. Essentially they just don't read at all.
TP1 - 07E0220917 / 046245090617 / 3010 / 0064040000000
TPA - 07E022093C / 04624509063C / 3010 / 0064020000000
TPC - 07E022091A / 04620509061A / 3010 / 0020000010000
TPD - 07E022091A / 04620509061A / 3010 / 0064020000000
Which X-gauge should I be using to see what my Throttle Position Sensor is doing? I have an '06 F350 SuperCab.
Thanks!
2006 F-350 XLT FX4 SCLB 6.0L | TTY head bolts | stock EGR and cooler | blue spring FP mod | PHP Atlas 40 FICM tune | ScanGauge 2 & GlowShift 3-in-1 gauge (Boost/EGT/FP) | PMM coolant filter kit | Flo~Pro 4" turbo back w/muffler | stock tune
Soledad is offline
post #2 of 2 Old 04-14-2013, 07:48 AM
amdriven2liv's Avatar
Quoted: 4 Post(s)
Try dropping a ZERO off the end of the MATH. If I'm counting right, I see 13 positions. Should only be 12.
2004 F350 6.0L CC LB 4x4 King Ranch
amdriven2liv is offline
