Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Electronics Discussion
Old 02-08-2008, 08:54 PM
hvyw8 hvyw8 is offline
Pics/schematic of relay flasher?
Does anyone have or know where I can find a pic/schematic of the relay flasher location on a 2004 f350?
Old 02-08-2008, 09:10 PM
SMKSTAX SMKSTAX is offline
<--------SWEET RIDE
You just need a pic of where the blinker relay is? I'll go take one if that's all ya need.
Old 02-09-2008, 07:52 AM
Please. I looked in the fuse panel and could not find it there. On the org everyone says that it is under the dash towards the right. Any help is appreciated.
Old 02-09-2008, 08:02 AM
mschn99 mschn99 is offline
Banished
its actually to the right of the "knee" panel you remove to see the fuse panel....its on the other side of the brace that is on the far right hand side of the knee panel....
What problem are you having??
Banished
his is gonna be different than an OBS one rick.....
Old 02-09-2008, 08:13 AM
Flashers are working just fine but the signals flash really fast. There are some days that they will be flashing and then just hold steady. Drives me up the wall!!! Then the next time that I go out they are flashing fast again, but at least they are working. All of my bulbs are working and I can't seem to figure this one out.
Old 02-09-2008, 08:16 AM
<--------SWEET RIDE
I found 2 possibilities:
# 18 20A Turn lamps-
#211 Backup lamps relay-
Hope this helps.
Old 02-09-2008, 08:17 AM
<--------SWEET RIDE
Ok where is it i have an 04 too.??
Old 02-09-2008, 08:23 AM
Hope this helps.
Thanks, I will give it a try.
Old 02-09-2008, 08:55 AM
Diesel Nick Diesel Nick is offline
I have excessive flatulance!!
Tournaments Won: 1
Send a message via AIM to Diesel Nick
usually when ur blinkers blink really fast its because one of your bulbs is burnt or the socket is messed up shorting out... atleast thats the case on the VW's I work on...
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
