What power inverter do you have/recommend? - Ford Powerstroke Diesel Forum
post #1 of 1 Old 04-04-2013, 12:58 PM Thread Starter
Quoted: 76 Post(s)
Well my power inverter died on me and I'm wanting to replace it with something decent. Not needing anything large....thinking that 400W unit would suffice. I'll be using the power point outlet and not the cigar lighter as the power point is dedicated whereas the cigar shares it with the OBDII port.
So if you have a power inverter that runs off the cigar type plug, what brand and size do you have and is it modified or pure sine wave? And is it loud (I don't want one with a screaming fan!)?
Thanks!
Phil
2004 F350 Crew Cab, DRW, Long Bed, 4x4
B&W Hitch, Edge CTS with EGT Probe and EAS Pressure Sensor, Dieselsite Coolant Filtration System, Firestone Ride-rite airbags with compressor, Blue Spring Update, Bilstein HD Shocks, DC Power 185 Alternator, 6.4 Starter, '08 trans pan & filter, BPD water pump, snow plow fan clutch, BPD 6 Phase FICM, Racor CCV6000 Closed CCV Loop
jd4010 is offline
