Mystery wire help - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-03-2013, 08:56 PM Thread Starter
Mystery wire help
Hi,
I just bought a 2007 F350 crew cab long box. It came out of the oil services industry. I ran across some wires that were cut and cannot identify what they are for and whether they are factory or not. Can anyone help? Here are some pics:
This is underneath the door sill on the drivers' rear. There are two distinct sets of wires; one in the loom and the other thick insulated one.
Here is a close up of the two wires:
I then found a third wire shown in the picture below (far right wire). It looks like a coaxial cable to me, but not sure.
The thick insulated cable ran under the driver's side rear and front sill and ended up under the front floor mat. It is a cluster of about 20 individual wires. In the picture below, it shows two sets. I think the thinner one is for the OBD, but am not sure. The OBD plug is another story for later.
Thanks!
aruba is offline
post #2 of 4 Old 04-03-2013, 09:00 PM
6.4L-NREMT-P's Avatar
the bigger one looks like a lightbar control wire you know like a beacon light bar, or it could be trailer wire but not sure why it would be running through there??????
2010 F250 6.4L Powerstroke 4x4 King Ranch
S&B Stage 2 CAI
MBRP 4'' DPF/CAT delete pipe w/Bungs
DPF-R plus 70HP tune
EGR Deleted
Custom Intake Elbow
Sinister Coolant Filter
Mishimoto Aluminum Radiator
6.4L-NREMT-P is offline
post #3 of 4 Old 04-05-2013, 12:39 PM
Definitley doesn't look factory. If I had to take a guess it was for a CB radio. The coaxial cable could have been running to the bed for the antenna mount. I have never seen the wiring on a CB before but I have seen VHF's and they use a coaxial cable for the antenna. A lot of people mount their CB radios in front of the center console which would explain why it's coming out at the OBD port. Also with the truck coming out of the oil field industires, i have no doubt that they would have had a CB radio. In that truck. Someone did a number on that OBD port though.
2006 F250 King Ranch 6.0L - 2.5" Leveling Kit w/ 4" rear blocks, ARP Studs, EGR Delete, 4" TB MBPR Straight Exhaust, SCT Tuner w/ Quick Tricks, Innovative, and Gearhead tuning, Blue Spring Upgrade, Dieselsite Coolant Filter, ScanGuage II, Dyno-Tune EGT guage, High Idle, Custom Wood Steering Wheel, PAC Aux Input, Ipad Mount, 5% Tint all around w/ 50% Windsheild Tint
Timbo126 is offline
post #4 of 4 Old 04-05-2013, 02:29 PM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
Not factory wires.
I'm thinking along the lines of a lightbar cable and a 2-way radio wire...
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
