Odometer trick fail - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-01-2013, 05:27 AM Thread Starter
Odometer trick fail
Tried the odometer trick for funsies. The display lit up "test" and then all segments lit up with 8's. Pushing or holding the reset button does not cycle through the various parameters. I just have 8's. Turning they key off and on does not help.
Did I break my cluster?
I can disconnect the batteries at lunch.
berusch is offline
post #2 of 3 Old 04-01-2013, 07:28 AM Thread Starter
Disconnected the batteries, cycled the headlamps a few times, reconnected the batteries. Dash is fixed, and it actually entered test mode correctly.
Test mode is kind of neat.
Pulled a DTC 9352. I assume it has something to do with the batteries being disconnected.
berusch is offline
post #3 of 3 Old 04-01-2013, 11:20 AM
Slacker
Evil Eye's Avatar
Quoted: 219 Post(s)
Feedback Score: 4 reviews
I've never tried so I can't help. A Google search indicates that this is a common code when you do the odometer test.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
