2 problems with new truck: overhead console and back up radar - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-31-2013, 12:57 PM Thread Starter
The display in the overhead console in the truck I bought a few weeks ago does not work. Is there a common problem I should look for?
Also the back up radar does not work. The "off" light on the button is lit solid. Is there a way to get the system to report trouble codes?
I don't mind digging into stuff and figuring out. I have an advanced electronics background, but time is very limited right now due to a newborn.
Thanks for any help. Please link me to appropriate threads if they already exist (I promise that I did search first).
<edit>
Should probably mention that the truck is an 03 crew, 4x4, 6.0 auto.
berusch is offline
post #2 of 8 Old 03-31-2013, 10:16 PM
soccerman's Avatar
Not sure if I can help you with the console except double check all fuses.
As for the backup sensors, my buddy had the same problem and we found out that one of the sensors on the bumper was not working. It is helpful to have a second person to help you for this. One person in the cab steps on the brake and has the parking brake on then puts it in reverse while the other person goes behind and listens. (Make sure you trust that person not to release the brake because you will be behind the truck. Safety First). When the truck is in reverse and the button is on, listen to each sensor carefully. You will hear a ticking sound. If you don't, then you know the sensor is faulty. Replace the sensor and you should be good again.
Try that. Hope that helps you.
2006 F350 Lariat
TowBoss Package
Front & Rear Camera
High Idle Mod
Rear Flood Lights
58V Swamps FICM
Remote Start
Straight Pipe
HID Head Lights
BD Heavy Duty EGR Cooler
Blue Spring Upgrade
STC fitting Upgrade
New IPR
Standpipes/Dummy Plugs
Lockpick
soccerman is offline
post #3 of 8 Old 04-01-2013, 01:31 PM Thread Starter
Per alldata, fuse #27 under the steering column powers the overhead console. It's good. At some point I will find the time to pull the console down and check for power and ground.
Key on, engine off, parking brake on, vehicle in reverse: Backup lamps on, no ticking sound heard from any sensor.
The parking radar off lamp is illuminated all the time.
berusch is offline
post #4 of 8 Old 04-01-2013, 03:14 PM
midnite rider's Avatar
Quoted: 285 Post(s)
Had same problem with overhead console burned out resistor, was a guy on internet would fix for around 30 dollars, can`t remember sight but will try to find it . Took about 4 or 5 day turn around.
-Tom
05 250 KING RANCH CCSB,278k,ARP's,SCT TSX,Atlas 40,STC done,Glowshift FP Gauge,Banks IC System,Blue Spring,Banjo's,CCV mod,Oil Bypass,Diamond Eye 5" Exhaust,Bilstein 5100's,RC Dual Steering Stabilizer,Retro 55W 6k Heads 3k Fogs,Continental Airbags,RSD 48 gal Aux Fuel Tank.
2003 F350 Lariat CCSB, 288K, Everything But Studs.
midnite rider is offline
post #5 of 8 Old 04-01-2013, 04:37 PM Thread Starter
I pulled the overhead console. The connector had +12V and ground, so I opened the display up. There were 3 resistors that were not properly soldered to the PCB. 2 lifted each on 1 side, the 3rd had completely removed itself. I resoldered the resistors and the display is now functional.
Would still like to know diagnostic info for the back up radar system.
Thanks
berusch is offline
post #6 of 8 Old 04-01-2013, 04:44 PM
Quoted: 285 Post(s)
glad console is repaired 300 dollars at ford. only thing i can think of for back up alarm would be corrosion
-Tom
post #7 of 8 Old 04-15-2013, 12:42 PM
For checking the backup sensors, You can just put your finger on the sensor and you will feel it ticking/tapping incase you have bad hearing. I have 2 bad sensors right now that I want to replace but dont really want to spend $100 plus dollars to do it.
05 CC SB 6.0 FX4
SCT w/ SPD
Gryphon Tuned
ARPs
New UCF Heads ported & Oringed
Blue fuel spring
sinister coolant filter
Egr Delete
5" DiamondEye TBE
BFG ATs 35s
ELC Cat-1
Scangauge
EGT/ fuel/ oil psi gauges
Bilsteins Shocks
08+ Aluminum Axle Cover
08+ Trans Pan W/Filter
MTW stage 2 DD solenoid
24+ years Ford Employee
SharkDiver is offline
post #8 of 8 Old 04-15-2013, 06:10 PM Thread Starter
I have not had time to look into it any further, but it's not a sensor problem. The disable light illuminates with key on, not when I go to reverse.
berusch is offline
