? on running lights - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-19-2013, 05:10 PM Thread Starter
MooreSix0Stroker's Avatar
Garage
? on running lights
I like to have on running lights when towing trailer even in day light. But it dims the dash making it hard to read. Is there a way I can wire a upflipper to turn on only the trucks running light ie (parking, clearence, and mirror) ?
John
07 F350 cc/sb Fx4 Lariat
ARP studs, OEM
head gaskets, 4" exhaust turbo back 6" tip, egr delete, BPD oil cooler and filtration, sct turner, egde insight monitor, coolant filter, high idle mod, Recon smoked mirror and cab markers
MooreSix0Stroker is offline
post #2 of 5 Old 03-23-2013, 09:06 PM
soccerman's Avatar
I just put my lights on auto setting and covered the sensor on the dash with black tape. That way you can just forget about the lights cause they are on all the time. I like to be seen. As for the upfitter switch, guessing you could just splice into the wire behind the dash and run it to the upfitter but you would have to splice into it before the sensor.
2006 F350 Lariat
TowBoss Package
Front & Rear Camera
High Idle Mod
Rear Flood Lights
58V Swamps FICM
Remote Start
Straight Pipe
HID Head Lights
BD Heavy Duty EGR Cooler
Blue Spring Upgrade
STC fitting Upgrade
New IPR
Standpipes/Dummy Plugs
Lockpick
soccerman is offline
post #3 of 5 Old 03-24-2013, 07:51 PM
pwrstroke6john's Avatar
? on running lights
I would think it would be easier for you to place your switch between the power and your gauges. That way you can turn the running lights on without the dash lights. Course then when it is dark you would have to hit the switch for the dash lights to come on. With a little time you should be able to wire the dash lights to feed off of the headlights instead of just the running lights too.
Sent from AutoGuide.com App
2005 F350 crew cab short box
6 inch pro comp lift
35x12.50-20 Nitto Trail Grapplers
Moto Metal Rims
5 IN MBRP Turbo Back Straight Pipe - 6 IN Tip
AFE Cold Air Intake
SCT Tuner
Coolant Filter
EGR Delete
15% Window Tint
6000k HIDS
Bushwacker Flares
Buckstop Front Bumper
Custom Rear Bumper
Weatherguard Box
pwrstroke6john is offline
post #4 of 5 Old 03-25-2013, 03:41 AM Thread Starter
Garage
Hadn't thought of that, thanks
John
ARP studs, OEM
post #5 of 5 Old 03-25-2013, 05:22 PM
RetiredFD's Avatar
I just throw either a black or tan soda bottle cap over the sensor and they come on all the time too
- Chris
2006 F250 CCSB Lariat
RetiredFD is offline
