Out of town, slow crank, HELP please. - Ford Powerstroke Diesel Forum
Old 03-15-2013, 03:22 PM
I am out of town until tomorrow. Problem started today with a slooow crank. Starts fine after running a while, but drains back down in a couple hours. Load tested batteries at O'reilly, said they are fine. Tested alternator, said it has low amperage and bad diode.
My question is, can a bad diode cause a drain on the batteries, but still charge when driving? If so, Can I just unhook the alternator tonight to keep from draining batteries overnight, and hook it back up for my drive home in and morning. I'll fix it all when I get home just don't have the means to change an alternator right now.
Thank you!!
Sent from AutoGuide.com App
Old 03-15-2013, 03:58 PM
yes a bad diode can cause a drain overnight. cause the dioides are what is called a zener diode which works as a one way valve of electrical flow and a bad one will let battery power run to the alternator field at all times ad drain batteries.
yees you can just unhook your alternator and re-hook that should help
Old 03-15-2013, 04:13 PM
That's what I was hoping to hear. Thank you sir!!
Old 03-21-2013, 01:04 PM
Not to bust chops,but.... Alternator on these can be changed in the parking lot with 2 simple wrenches.
