06 F-350 constant draw - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-14-2013, 06:11 AM Thread Starter
Hello all. I'm having an electrical issue and this looked to be the best place to post about it. The other day, we went to move the dump truck and it wouldn't start. This has happened a few times so I figured it was time to see what was going on. So i put it on a charger for most of the day and got it into the shop.
Load tested both batteries and they tested good. Alternator is putting out 14.2 volts. Disconnected both batteries and tested for draw, and it has a 1.5 amp constant draw.....a bit too much I believe. Next i start pulling fuses to pin point further. #2 10A circuit that the Owners manual simply calls "Cluster" (in addition to fuse #35 for Instrument Cluster).
I have a Haynes manual covering 1999-2006 F-250 & 350 Super Duty, but cant find that particular fuse or the corresponding circuit. If anyone has some insight into this, I would greatly appreciate some guidance.
I could just put a battery tender on it and not worry about it, but I like a good electrical challenge Thanks in advance.
EDIT: I've noticed that when the #2 fuse is pulled, it does NOT affect instrument cluster operation, although it did seem to idle a little rough. So I'm wondering what "cluster" the owners manual is talking about. Odd. Going to be a nice head scratcher.
vadieselnoob is offline
post #2 of 7 Old 03-15-2013, 06:42 AM
Quoted: 3 Post(s)
Fuse #2 shows on the schematics as being battery supply to the cluster. Doesn't appear to go anywhere else.
Be sure you have followed the battery drain test procedure (see page 14 of the attachment). Not all modules go to sleep right away.
Lee
ve7fet is offline
post #3 of 7 Old 03-15-2013, 10:17 AM Thread Starter
Thanks for the info. I will report back with what i find.
post #4 of 7 Old 03-15-2013, 11:03 PM
Sno-Mow's Avatar
Re: 06 F-350 constant draw
Was it raining at all? I had same issue, found the windshield gasket was leaking and dripping down behind the fuse panel. Sealed the windshield and no more issues.
2003 F250 6.0l
281,000 miles and counting
EGR Cooler Delete, A1 Studs, 3.5" Down Pipe, 4" Straight Pipe, Turbo Rebuilt, New OE Heads, New HPOP, New Injectors
Blizzard 8611PP
Because you won't push it with a gasser!
Sno-Mow is offline
post #5 of 7 Old 03-20-2013, 04:27 AM Thread Starter
Sorry about not replying sooner.
Lee
Following the procedure, fuse 103 (ignition switch) is drawing .03-.14 amp and fuse 2 (cluster) is drawing .45 amp
Also....this is with the key out of the ignition switch
I'm aware of the leaking windshield gasket problem, but I don't see any signs of it leaking. One of the first things i checked, just failed to mention that lol.
post #6 of 7 Old 03-20-2013, 07:27 AM Thread Starter
Also, unplugging the ignition switch connector has no effect on the 103 fuse circuit. It still shows a .12 amp draw. i'm more concerned about the 1/2 amp draw in the cluster circuit, so will be concentrating my efforts there.
post #7 of 7 Old 03-20-2013, 05:11 PM
Start by cleaning all your ground contacts and use battery saver
01lightning04stroke is offline
