Well guys i set out to figure out a way to get "safe" 12v sources into my truck for running all the good stuff, after blowing many fuses inside of my truck and spending $1000 for a shop to diagnose that i had blown my "internal" starter relay in the fuse panel.
I never wanted to blow another fuse on my truck from overloading circuits and also did not want a huge mess of relays sitting under my hood.
My solution was to make my own fuse block in which i left mounted under the hood. The panel was bought from a local oilfield supply store, would fit standard fuses, was rather small and i think cost me $10. Now comes the deal of running mutiple relays and trying to keep them organized somehow.
i decided to mount the panel on a small piece of plywood painted black and mount the relays on the back side also installing a ground post on the back as the panel didnt have one already. this was the cleanest and easiest to trace method i could think of.
i used 6 gauge red wire fuse holder to the block and since i couldnt find any black 6 gauge wire, i grounded it with 4 gauge. In total i used 8 relays on the bottom of the panel, only currently using 4 of them. giving me 4 relays unused and 3 12v sources unused still.
i mounted it in the small area of space behind the brake fluid reservoir. by mounting i mean i connected all my wires and laid it in the and it seems to stay. i drilled small holes in 4 corners of the plywood and if i felt inclined i could zip tie it to surrounding items in the engine bay but this gives me some wiggle room being able to access the bottom relays easily.
ill post up some pics and you electrical gurus let me know what you think,
steve
and just for giggles one photo of the recons I installed, still waiting on second set of fog lights from ebay seller. who knew my truck was an 04???
