| 6.0L Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
won,t crank with the key
shut 06 f 350 off, 15 minutes later wouldn,t crank with the key!! checked fuses, lossened starter and banged it in case was locked up. an hr. later had a brain fart and pushed the remote start button, truck fired up!! shut it off and tryed key with no luck, fired backup with remote start!!! does remote start bypass all safties for low oil psi and low fuel psi?? what else could cause this ??
when using keyless entry
on this truck an 06 6 litre the locks have to be cycled to activate the ignition again.
