05 possible GEM module problem - Ford Powerstroke Diesel Forum
post #1 of 18 Old 02-09-2013, 06:28 AM Thread Starter
hazard's Avatar
hello guys its been awhile since my last post but here goes, 2 weeks ago i diagnosed and installed a new injector in my friends 05 6.0. i noticed when i road tested it i had no radio power (clock and the button lights all worked okay) no map lights, no power windows (door locks worked okay) also i have no light under the hood. now i did absolutely nothing with any of these items changing the injector. my friend has never had the issue with the truck. i pulled the GEM codes with my mac mentor and seen it does have a U1900 code for a controller failure, there is also another code for the keyswitch, but everyone says its a ghost code that will go on if ur door chime or something dont work. ive tested the fuses all okay, but i have no voltage to either side of them... i have researched a bit and really am not coming up with nothing other than the gem module may be toast but i dont really want to spend 300 bucks of my friends money on a whim, im a big fan of diagnostics lol. as of now i can find or think of any other fuses or connection issues that would only effect those few interior items. at this point i am afraid im looking at a GEM module. any info or help would be AWESOMELY appreciated. thanks again guys
Thanks,
Adam
2006 F-250 6.0L CCSB Lariat 4x4, ARP studs, SCT tunes by innovative diesel, Silverline 4" turbo back exhaust no cat no muffler! Upfitter switches w/high idle mod, Edge Insight monitor w/EGT probe, autometer fuel psi gauge, Zoodad mod with billet plate. Ford Updated fuel psi spring and banjos, RCD egr delete, Ford updated oil cooler and stc fitting, dieselsite cac boots and coolant filter.
1984 Mercedes Benz 300D Turbo Diesel, cold air intake.
"Run Hard, Dream Big"
hazard is offline
post #2 of 18 Old 02-09-2013, 07:01 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 19 Post(s)
They don't have GEM modules anymore. Your instrument cluster is causing your issue.
dhanna6powerstroke is offline
post #3 of 18 Old 02-09-2013, 07:10 AM
ZMANN's Avatar
Quoted: 1346 Post(s)
an 05 has a GEM
thats the unit everyone looks for to read their door code off of under the dash behind the radio
We Miss you Ronnie
ZMANN is offline
post #4 of 18 Old 02-09-2013, 07:12 AM Thread Starter
hazard's Avatar
could you explain in a little more detail? what year did they quit using gem modules? im not familiar at all with interior problems, i am an engine/drivetrain only guys lol
Thanks,
Adam
hazard is offline
post #5 of 18 Old 02-09-2013, 07:17 AM
Mod Newbie
Quoted: 19 Post(s)
I guess I spoke too quickly. I thought they got rid of the GEM and started using and calling them VSM's. At any rate, had a couple friends lately that have had similar issues and it has been the cluster. Sorry for the misdirection.
post #6 of 18 Old 02-09-2013, 07:20 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 9 Post(s)
Dougs correct its a VSM not a GEM. It hasnt been a gem since 03
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #7 of 18 Old 02-09-2013, 07:23 AM
ZMANN's Avatar
but the module whatever you want to call it?? so I will refer to it as a Module LOL does all the same items as the old term GEM doesn't it ?
like retained power after key of ETC
I know the dash has a lot of responsibilities also
We Miss you Ronnie
ZMANN is offline
post #8 of 18 Old 02-09-2013, 07:49 AM
ZMANN's Avatar
I guess not the VSM doesn't do retained that looks like a separate relay ( oem manuals and all data )
interesting Learned sumptin new thx guys
We Miss you Ronnie
ZMANN is offline
post #9 of 18 Old 02-09-2013, 07:51 AM
Mod Newbie
Quoted: 19 Post(s)
Pretty sure an instrument cluster will fix the issue.
post #10 of 18 Old 02-09-2013, 08:14 AM
ZMANN's Avatar
ouch they are around 350 ++
but you can just swap them correct ?
not like MY GM that had to be sent out and reset the mileage to existing
the Ford is in the PCM ?
We Miss you Ronnie
ZMANN is offline
