| 6.0L Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
alt low output ?
2005 f350 single alt
my battery light came on last night when driving home .so im guessing my alt is toast when my rig is running its putting out 11v ? shouldnt it be like 13.8-14 ? |
11 is way too low. get it worked on before you need to replace batterys and the ficm then maybe injectors. an alt is way cheaper than the other three.
bailey |
Good time to upgrade
ill park it till i go grab a replacement
Sounds like what my truck did this week. This is what I found:
Analysis of an Alternator Failure Lee |
so i replaced the alternator drove it for a day damn battery light came back on on my live wire screen its dropping to 10-11 volts on my batterys ? im thinking i need to replace both batteries ????
after i replaced my alt, i had to replace my batteries also. do both of them, the weaker one will draw from the new one and you will eventually have to replace both.
bailey |
just replaced my batteries started driving down the road BAM battery light came on again showing a p0675 code WTF !!!
bad # 5 glow plug
and a bad alt is my guess ,,, fix the alt issue first and the gp may go away must have a warranty did u by a cheapo ? |
When the alt went on my 05 it took 2 before i got a good one
