- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
| 6.0L Electronics Discussion TV's, Radios, everything electric and NON-Performance. |
HIGHEST CCA BATT
I'm having problems starting my truck at -30 I put two new 850cca batts in but still not enough juice for the cold mornings I have always run 1000cca in all my other trucks but I can't seem to find any to fit my 04 anybody got any ideas on what the highest cca batt that will fit
| Sponsored Links |
How's the weather???
Replaceing your batteries might not accomplish what you are trying to do. The 2007's were specked out from the factory with 750 cca's ,so I am reasonably sure your batteries are up to specs capacity wise.You might think that increasing your cca's by 19 percent is going to give you a 19 percent improvement. This is not necessarily the case. You would only see that kind of improvement if your load resistance MATCHES the load resistance of the manufacturers test load when they rated the battery. To see the improvement you need in current supply,the money would be better spent on upsizing your cables,your starter ,and beefing up your starter solenoid(gold plateing???). The comparitive resistance is much higher here than internally of your battery. I suspect that assuming your 850's are like new,your current gain is going to be minimal with 1000 cca batteries. I suspect that ,with those minus 30 temperatures, you should be using a fresh change of synthetic oil,if your not already.( along with your block heater) and a nearby bonfire. |
cold as hell
I have fit 1000cca bats in my truck no problem. I guess it is just a matter of finding them.
| Sponsored Links |
