Batt V drop when subs hit - Ford Powerstroke Diesel Forum
post #1 of 17 Old 01-28-2013, 11:07 AM Thread Starter
DoubleDpsd's Avatar
For people with subs .....does your battery voltage drop when your subs hit? I have a 500watt mono feeding four 8's. And a 300watt 4channel powering the door speakers and tweeters. Im sure its normal just want to confirm. Hope these batteries aren't already getting tired. Thanks
2003 centennial edition f250 4x4 ccsb auto w/blackwater long block w/arp's, 4" exhaust, airaid intake, ODawg's manifold, itp's reg return, sap modified solenoid, DC power 185amp alt, motorcraft 850cca, Warn Hubs, RS 55w 6k hid's, harley headlights, bpd 58v 6 phase, bpd water pump, dieselsite coolant filter, elc coolant, php gryphon, Xcal2 w/unlimited tow, new hfcm, glowshift fuel psi gauge, icon level kit, 20" kmc hoss, 305/55 terra grapplers TOTALED
DoubleDpsd is offline
post #2 of 17 Old 01-28-2013, 11:11 AM
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 21 Post(s)
Feedback Score: 12 reviews
You need a capacitor man
Sent from AutoGuide.com App
2017 f250 platinum
Deleted at 8k miles.. trying to be patient waiting for custom tunes...
mts678 is offline
post #3 of 17 Old 01-28-2013, 11:15 AM Thread Starter
DoubleDpsd's Avatar
Re: Batt V drop when subs hit
With two batteries? Really!? My trusted audio guy didnt even recommend one.
post #4 of 17 Old 01-28-2013, 01:51 PM
Quoted: 28 Post(s)
Yes a capacitor would help.
Was this at idle? Your alternator can only charge so much at idle compared to running speed(1500-2500). Take. a look at dcpower alternators if so
06 350 CCLB
Edge CTS
Up-Pipes by Cutting Edge
ARP's
Bulletproof EGR Cooler
Coolant filter
rentstdi is offline
post #5 of 17 Old 01-28-2013, 02:40 PM
twoicebergs's Avatar
Quoted: 47 Post(s)
I have 16 speakers and 3 amps in my boat. If we crank up the sub and hits hard frequently it certainly sucks the power. I only have 2 batteries (heavy high amp hour deep-cycle and no caps), but have used large caps in previous applications. They work, but the warnings are real, use large wires, make sure they are protected, and never handle wiring or the caps unless you know they are discharged.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #6 of 17 Old 01-28-2013, 03:20 PM
I have a 500w mono amp powering 2 10" subs and I don't see any noticeable drop in voltage.
2004 F350 CCSB Lariat FX4
Powermax
Edge CTS w/ EGT, Fuel Pressure
SCT tuner with Innovative Tunes
Fleetrite ELC, Rotella T-6
MBRP 4" turbo-back straight pipe
XDP Coolant Filter
NUC Motorsports Oil Bypass
Pioneer AVH3500BHS head unit, backup cam, Sirius/XM, Kicker speakers, Kicker 500.1 Amp, 2x Kicker 10" subs
89Foxbody is offline
post #7 of 17 Old 01-28-2013, 03:32 PM
Premium Starfish Member
AzPatMan's Avatar
Quoted: 39 Post(s)
Ok...
When you're playing loud and drawing a large hit on the sub - you're amp is pulling more voltage than can be supplied/sustained. Hence while I agree you should get a Capacitor as well.
Because then you're going to be pulling for the stored energy in the cap first (which will recover also a little quicker) then straight off the battery.
It helps to sustain the voltage sure,,, but for hard hammering - you'll want a cap.
2003 EX, 7.3L 4inch Lift, Nitto Trail Grappler's, KMC XD Spy's
220k Miles, Currently 605tq, 312hp
AzPatMan is offline
post #8 of 17 Old 01-28-2013, 03:37 PM
Quoted: 47 Post(s)
You really have to have it cranked. You probably couldn't sit in the vehicle if it was hitting hard enough to pull that kind of power. But every once in a while someone drives by with bone shattering base blasting, way over powered and occasionally clipping. The 10" Kickers don't seem to suck the power, like some other subs, but SPL and over-driving amps can cause a brown-out. I have Kickers in my boat and they work just fine. Of course we are old and never play are tunes too loud when surfing.
Frank
Working for Toys
post #9 of 17 Old 01-28-2013, 03:42 PM
AzPatMan's Avatar
Quoted: 39 Post(s)
Keep in mind - not all equipment is equal and efficient on power draw.
I seen little jensen, pyramid amps cause voltage drops powering subs,
while same watt amp from alpine, sony etc does not.
There at least 4 to 5 different reasons why voltage drops can occur feeding an amp.
But rule 1 - you have to have a contant/stable feed of power.
AzPatMan is offline
post #10 of 17 Old 01-28-2013, 03:47 PM
AzPatMan's Avatar
Quoted: 39 Post(s)
Also - Deep cycle batteries are what is helping you there.
they are intended for high power draw.
This is why people used them for Stereo, Winches, etc.
They're designed to provide high flow of power on demand to the point of being drained - then charged back up.
AzPatMan is offline
