FICM life expectancy? - Ford Powerstroke Diesel Forum
post #1 of 28 Old 01-18-2013, 08:11 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
Just got my OASIS report tonite ( thanks to FORDDIESEL DOCTOR!!) Got to reading it over and I notice a couple things...
1-first FICM died at 77,000 miles. 2nd ficm was near death with me at 105,000. What is a goold long life for a FICM ( under ideal conditions)
2. I also noticed that the new tranny I just had put in wasnt on the report. Is a oasis report something that FORD is supposed to keep current when possible or something for the original owner only?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #2 of 28 Old 01-18-2013, 08:52 PM
JayAF98's Avatar
Re: FICM life expectancy?
Not sure what everyone else is seeing. Maybe I got lucky that mine is over 170k and on the original OEM one. Voltages still never drop below 48.
Sent from my DROID RAZR HD using AutoGuide.Com Free App
JayAF98 is offline
post #3 of 28 Old 01-18-2013, 08:53 PM
JayAF98's Avatar
About the tranny, if a Ford dealer installed it, it should be in the report from my understanding.
JayAF98 is offline
post #4 of 28 Old 01-18-2013, 09:00 PM
ZMANN's Avatar
Quoted: 1355 Post(s)
if you let your batteries go weak you hurt the FICM
so it's a per user variable .. Mine went at 75k but always had great batteries
however I also monitor My FICM and it was just dropping to 42 volts ,, it May have lasted for a long time if you weren't watching
We Miss you Ronnie
ZMANN is offline
post #5 of 28 Old 01-19-2013, 04:41 AM
kcoyner's Avatar
Quoted: 57 Post(s)
162k and voltage stays between 46.5 under a load and 48.5 at idle.
K
2005 F-350 Lariat DRW, Asheville Engines Performance 20 Long Block with ARP studs and a Stage 2 Cam. EGR Delete. SCT tuner. Salvaged Banks High Ram Intake Elbow, Ram Air Filter and IC. Amsoil lubricants, Sinister Coolant Filter, Edge Insight CTS, SP Performance Rotors and Hawk Tow Pads, Motorcraft fuel and transmission filters, Mishimoto radiator, thermostat and silicone hoses. BulletProofDiesel water pump and Heavy Duty Oil Cooler. Marty's Diesel Regulated Return
kcoyner is offline
post #6 of 28 Old 01-19-2013, 06:02 AM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
Ive started to do everything needed (as far as I know) for a long healthy FICM life. I was just suprised to see that I was now on FICM #3 for the truck. Makes the BPD ficm easier to pay for.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #7 of 28 Old 01-19-2013, 06:13 AM
ZMANN's Avatar
also some strategies were known as "FICM" killers
We Miss you Ronnie
ZMANN is offline
post #8 of 28 Old 01-19-2013, 06:47 AM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
Did not know that
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #9 of 28 Old 01-19-2013, 07:32 AM
Slacker
Evil Eye's Avatar
Quoted: 192 Post(s)
Feedback Score: 4 reviews
I went through a couple as well and even the "spare" that I bought and had fixed started dropping voltage. It was loaned out to several of the staff here at the ORG and despite being "fixed", it still went bad. It's one of those parts that until you replace it with a more reliable part (like the BPD), you will always have to monitor and wonder... I don't even watch FICM voltage any more.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #10 of 28 Old 01-19-2013, 07:46 AM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
Mine worked past 170k miles, I just replaced it with the Bullet Proof Diesel FICM.
It was still starting strong and maintained 48.5 volts contantly when it was pulled.
Now it sits as a back-up.
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
